worn out hood supports suck
    Replace the 20'sh year old hood shock with a new OE part.
    • IRON-E
      • 16548
      If your cheap asses don't want to spend a whole $25.00 for a new one, just lock your vise grips on the old shock shaft., Works perfectl every time. ;)
      @IRON-E30 aka Edwin:D
      • AndrewBird
        The Mad Scientist
        • 11898
        You can also tighten the nut that is on the pivot point. Takes a couple seconds with a 10mm.
          • 37833
          Originally posted by enigmaticdream
          2x4s work too.
          Owns $15,000+ E30 M3. Uses 2x4 for hood prop.
          Grover Beach, California
          BimmerHeads.com
          • andrewm
            • 456
            I use a broken shovel handle whenever I'm doing something that will move the car around, or when I've got it on ramps or stands. I've also had wind close hoods before, so I'm very careful about it.
            1987 Delphin 325e Sedan - Natalie
            1990 325i 24v
            1997 Chevrolet K1500 Crew Cab 4x4 - The Centurion
            • AbsorbantNut
              Non faccio funzionare questa merda
              • Jun 2010
              • 2491
              I use a skateboard. Or my floor jack handle
              '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
              • bimmer2288
                • Feb 2006
                • 273
                That's what I thought too.
                • jaywood
                  • Jul 2010
                  • 4528
                  I've had it a fall on me a few times. I got a PVC pipe now that holds it up
                  • Saeulf
                    • Jan 2013
                    • 36
                    Ordered new strut (Stabilus) and took 5 minutes of my day to install it.
                    Done.
                    • SlamedIAm
                      • May 2011
                      • 318
                      Apparently that isn't the r3v way. Replacing that shock is one of the favorite things I've done to my car.
                      • AbsorbantNut
                        • Jun 2010
                        • 2491
                        Turbo is mine:p
                        • chance
                          • Feb 2012
                          • 671
                          the fucking thing is 10 dollars at guten parts. Just buy a new one. I did and it made a huge difference
                          1991 335is in progress
                          • mcaden
                            • Jun 2011
                            • 164
                            I replaced mine with an OEM hood strut and it works great now.
                            • Thizzelle
                              • 4422
                              why when there are plenty of golf clubs in my garage. that's a 100 part to hold up the hood :)
                              "I wanna see da boat movie"
                              "I got a tree on my house"
                              • z6ne
                                • Dec 2012
                                • 758
                                Just replaced mine with the spare that was in the trunk when I bought the car. Before I tightened the bolt down that attaches the metal piece to the hood then to the body, I tested it and it started to fall just like the old one. but once I torqued the bolt down and got it all lined up it worked
