If I buy a used Speedo and all the gauges
  • makecopies
    • Apr 2013
    • 124
    If I buy a used Speedo and all the gauges will I be able to turn the mileage back to closer to what mine is? all the ones I find have 200k+. My current car has around 150k
    I know with the E46 you would get the infamous tamper dot.
  • slammin.e28
    שמע ישראל
    • 12054
    You can. There is a writeup somewhere on r3v.
    inb4 legality debate.
    • rcsoundn1
      • Nov 2012
      • 3361
      could you roll it forward until it goes back to 150k?
      • slammin.e28
        שמע ישראל
        • 12054
        That's much more difficult.
        Just take it apart and roll the miles where you want them.
        Like it says, ~1hr tops.
        • brent5631
          • Jun 2012
          • 421
          Just drive in reverse.
            Why would you replace the entire cluster? Almost anything that can be wrong with it is pretty easily repaired.
            • makecopies
              • Apr 2013
              • 124
              I just got the car. The Fuel/Temp and the RPMS dont work the Speedo was working perfectly but lately its erratic. It drops down to 0 while im on the highway.
              The Gas and the Temp bounce up and down like a fish out of water.
              and none of the lights work at night when i turn the headlights on. I just want to repair everything and then move on to the other 2 major things I need done. The leaking convertible top and no AC
              • ST1G
                • Oct 2012
                • 6689
                This seemed to work well for Ferris. Highly recommend.
                • e30vert
                  • Jan 2005
                  • 1789
                  If your asking if its possible. Then YES by all means its possible as noted in the above link to the write up.
