Hey guys, got a 220v welder a while back from my GF. My shop only had 110 so the welder took a back seat to a couple other projects.
I wanted to get some experience with electrical so I've been reading up a little and am going to tackle this by myself.
I went to my local Lowes yesterday and purchased the following.
25' insulated 10-3 wire. (4 wires, red hot, black hot, white neutral, and bare ground)
30A double pole breaker for my Square D box
30A 3 post plug in (welder side)
30A 3 post receptacle (wire side)
I purchased a 3 post plug in because I have 3 wires in the cord coming from the welder (hot, neutral, ground) and figured I'd use a plug in to accommodate that.
However, I ran into an issue last night installing the receptacle to the 10-3 wire. The receptacle box has terminals to install only 3 wires, the two hots and the neutral and no where for the bare ground.
My box will accept the 4 wire cord but my questions is, where do I install the ground on the receptacle end?
I realize I could buy a 4 prong plug in and receptacle but then would be faced with not knowing how to install the plug on the welder side.
Thanks for the help
Thanks for the help
