Strange Part in door panel
  • apiazza2010
    • Nov 2013
    • 131
    i found this part in the door, though it was a piece of the door lock since my door lock does not worked, opened it up today and found this. Do you guys know what it is?
    Thanks
    LS1 91 325i - BC Coils, e46 m3 brakes,style 32 17x9, Red Plastidip, H/C/I
  • kronus
    • Apr 2008
    • 13028
    that's the door prop mechanism. It has a bar that rides in it and keeps your door propped open at two different detents.
    cars beep boop
    • Roysneon
      • 4505
      Yep, aka the door check. your door probably flops open and swings freely without it, unless that's the broken off portion of one that was replaced that ended up in the door from way back.
      Originally posted by mbonanni
      I am a pursit now.
      • apiazza2010
        • Nov 2013
        • 131
        That's why the door doesn't stay open!!, I will look at the other side and figure out what's wrong. Thank you very much for the quick help
        • blunttech
          • 12850
          Order this when you are ready to fix it
          41511884163
          sales@blunttech.com
          www.blunttech.com
          Like us on Facebook
          • Hochspannung
            • Oct 2013
            • 40
            You should definitely fix that. If a gust of wind comes from behind you it can blow the door open more and crush your front fender. Its not hard to replace; I had this problem once before as well.
