Sooo I'm sitting on the side of the roa right now.
  • Zreberlcoe
    • 1555
    I just got off work and my e30 completely cut out on me. It started bucking back and forth, back firing, and the tachometer was all over the place. I'm thinking it's the fuel pimp but I am not certain. Weirdly when the motor cut out on me my clock on my obc reset like I pulled the battery and my radio did the same thing, reset. I checked all my fuses since I was in my fuse box yesterday, non of them are blown. It could be my spark plugs as well because they're some crappy brand but they look alright.
    1991 325i Calypso Coupe
    Like Grandfather, Like Father, Like Son
    BMW
  • Zreberlcoe
    • 1555
    My dad is coming to get me now but I'm not sure what to do with the car. I'm about 5 minutes from home so should I limp it? It seems that when the motor warms up is when it gets problematic.
    BMW
    • Conki
      • 1254
      Did you check the battery fuse in the trunk?
      The fact that everything reset leads me to believe you lost battery contact somewhere.
      1992 BMW 525iT Calypso
      2011 Jeep Wrangler
      • ZM Blue Devil
        • Dec 2006
        • 13836
        Also check the relays on top of the drivers side strut housing, in the engine bay. There are 3 of them, seen where they get loose/pops up and car dies.
        Levent
        %20levent@gutenparts.com
        Ladies:
        • Zreberlcoe
          • 1555
          Check engine light never came on.
          BMW
            That sounds like a dead battery and failed alternator.
            • Zreberlcoe
              • 1555
              It keeps starting right up and I just got a alternator that was in good condition from a R3v member not too long ago. I drove it home and I kept it under 2000 rpm and it didn't sputter, got to the house and let it idle and it slowly but surely started dipping in the rpm and back firing, the quit. No sign of battery dead all electronics are on and will still turn over.
              BMW
              • Zreberlcoe
                • 1555
                Battery fuse in the trunk?
                BMW
                • UDMRacing
                  • Oct 2013
                  • 48
                  There's a fuseable link that runs parallel to the positive battery cable in the trunk area.
                  • delatlanta1281
                    Dart Master
                    • Mar 2006
                    • 10317
                    Grounds, CPS...
                    Yours truly,
                    Rich
                    you kids get off my lawn.....
                    • Zreberlcoe
                      • 1555
                      Originally posted by delatlanta1281
                      Grounds, CPS...
                      It seems fuel related due to it cutting out like it does.
                      BMW
                      • BillBrasky
                        • Dec 2008
                        • 1641
                        Grounds, CPS...
                        I would check these as well and I've even had a very clogged fuel filter cause the same symptoms before.
                        • Ocell
                          • Apr 2013
                          • 291
                          Your electronics resetting makes me think it's not fuel related. I just battled through fuel pump issues and the electronics never missed a beat. (Both a dying/dead pump and later a blown pump fuse)
                          91 318is Members' Rides Thread
                          • flyboyx
                            • 8371
                            sounds like the main relay to me? that is assuming you have an m20? thats the white one on the driver's side shock tower.
                            Gigitty Gigitty!!!!
                            • F34R
                              sLaughter
                              • 12385
                              How do they ever get loose for you? They take a jackhammer to get free...those 5 prongs are the worst.
                              Instagram: @BWeissLeather
                              Current cars:
                              ~ '87 325 M30B35 swap
                              ~ '87 535
                              ~ 01 540 Msport 6spd
                              ~ '06 X5 4.8is
