Can you guys answer following questions, let's pretend all of you are using Maintenr or something similar to manage your vehicle history:
1. Would you 'check-in' your vehicle to your local mechanic and grant them permission to view your vehicles service schedules/job history/tutorials/part lists/etc?
2. What about allowing them to add new service to your vehicle (you come in for an oil change, they add oil change service to your vehicle and setup a reminder based on specifications)?
Keep in mind that you remain in total control of your records and they can't modify previous records unless they added them to your vehicle. You can also login and revise any additions they made.
You will also be able to 'check-out' after you get your vehicle back and remove any sort of visibility to your data the shop had, they would only be able to view your basic information (as a client) and data they added to your account.
Basically kind of like (health records + foursquare + carfax) = for your car, controlled by you.
Should I do this or?
