Steering wheel nut won't loosen, am I going to break something?
  • rex
    • Nov 2013
    • 150
    The steering wheel nut is seriously over torqued, and/or has a hefty dose of threadlocker on there. This is a normal stock 4 spoke non airbag wheel.
    Trying to loosen the nut using a breaker bar, with the wheel locked, it feels like I am going to break the wheel lock if not the steering column.
    Is this likely? Or should I just go for it? I know sometimes working on stuff I have to give more force than "feels" safe to me, but given that it's the steering column, I really dont want to break anything
    I tried a search for 'steering wheel' (excluding the for sale forums), and found a fair number of people whose wheels were stuck on -- after they got the nut undone.
    If I borrow a power wrench or impact wrench, will that get it off without damaging things?
    I already tried spraying PB blaster in there, thinking that might help, but no change.
    This is driving me nuts because I really want to fix my odometer and temp gauge
  • nickmcc92
    • Dec 2012
    • 442
    Try holding the breaker bar in your right hand and steering wheel in left hand
    • jaywood
      • Jul 2010
      • 4528
      Have a friend help you. Hold the steering wheel while he breaks the nut loose. They are tightened very tight from the factory
      • rex
        • Nov 2013
        • 150
        already tried this method... maybe we are both just weak :/
        • Pantless Spency
          It's McRib time!!!
          • Feb 2011
          • 7283
          it needs some impact. put the ratchet on there and shock it with a mallet.
          when taking off the wheel work it side to side and dont pop yourself in the face.
          • LJ851
            • 7919
            Do you even lift, bro?
            An impact wrench should work or use a longer lever (pipe over the end of the breaker bar to extend it)
            Lorin
            The M30 is God's engine.
            • Ty13r
              • Aug 2013
              • 2
              if you scream while doing it you'll gain extra power. worth a try.
              • ST1G
                • Oct 2012
                • 6689
                Put some chalk on your hands.
                • roznic
                  • Mar 2013
                  • 2876
                  Have some beers first, then you won't give a crap about braking anything....;-0
                  • 3vilE30
                    • Jan 2013
                    • 344
                    Grab an extension, breaker bar and have some one hold it in place get out the car and kick the shit out of the breaker bar should work lol.
                    • rex
                      • Nov 2013
                      • 150
                      thanks to everyone for the replies, i guess we'll just have to try harder...
                      either way we did it, the one of us pushing on the bar + pipe over to lengthen was overpowering the one who was holding/bracing the wheel, with no apparent effect on the nut
                      so i take it based on this thread that if we were to do it with nobody holding the wheel, it would indeed break something?
                      • roznic
                        • Mar 2013
                        • 2876
                        Congrats man, but I am tellinn ya, beers!!
                        • ST1G
                          • Oct 2012
                          • 6689
                          Lock the wheel then try.
                          • 3vilE30
                            • Jan 2013
                            • 344
                            Make sure you're turning the breaker bar the right way too that would help A LOT...
                            • ST1G
                              • Oct 2012
                              • 6689
                              toward the drive side door...
