E30 Heated Seat Kits
Forsale Thread
This is a project I have been working on to help all you guys out
there keep your bums warm. Only a handful of E30s came fitted
with the heated seat option. Now, twenty some-odd years later,
sourcing a working OEM unit can be quite a hassle. Things get old
and rot out. The heating pads are not meant to last forever and
switches begin to go.
My goal is to provide a affordable alternative to the OEM Option.
I have put a lot of thought into product to make sure it will last long
and work efficiently. Below is some information regarding what this
kit will include.
Basic Information
I had been toying around with the idea of making heated seat retrofit
kits using modern heated seat pads. I have a supplier for the pads already and am
set on a design. The pads used are from a US company that makes
carbon fiber heating pads for car seats and other applications. They
heat up fast and stay at a comfortable level.
These pads can be used in any seat you like but i am open to custom
set ups for optimal heating for different sized seats and possible rear
pads for sedans. I can use different size pads for recaros and other
sport seat types and comfort seats.
OEM Switch
Aftermarket Switch
Features:
-Electronic thermostat (built into each pad) regulates the electricity / temperature
circulating within the carbon fiber seat heating pad. This system regulates the flow of
power and maintains a narrower temperature range whether in a high or low setting.
Example: The high setting will have a constant range between 120°F to 125°F. The low
setting ranges between 110°F to 115°F. These respective temperatures are maintained
at these respective levels.
Kits:
- 2 Seat Kit (with Aftermarket Switches)
- 2 Seat Kit (with New OEM Switches)
- 2 Seat Kit (for use with your own OEM Switches)
Each Kit Includes:
- (4) Carbon Fiber Heat Pads
- (1) Custom Wiring Harness
- (2) Switches
- (2) Dual temperature control module
- (1) Installation Instructions
I do not have any kits currently for sale.
However, If you wish to "prepurchase" a set I will provide them
at Discounted Price. The wait time will about 4 weeks
to have them made and shipped out to you. I AM TAKING ORDERS NOW
If you have any questions or concerns please leave some feedback below.
Forsale Thread
On a side note what would you guys think about Memory Foam Sport Seat Foam Sets for upholstery?
