I need some urgent help R3vers, I'm at a stand still with putting my rear subframe on my E30. The plan is to use a rear subframe I got out of a '90 325ix so I can weld in some camber/toe adjustments on that one while still being able to drive the car and today I attempted to switch them out and everything went well until installing the rear drive shaft onto the IX diff. It seems that the driveshaft flange is not wanting to mate up with the IX flange and I can't figure out how to get them to mate up.
here's what I'm working with, the center carrier bearing is bolted in.
SAM_0208 by eberlcoezack, on Flickr
When I was pulling it off I had to use a screw driver and pry it apart and drop the center carrier bearing. What in the F is going on. HELP
