What are some desirable 323i engine parts?
  • markt51
    • Apr 2012
    • 329
    About to return my 323i engine for a core charge, and im in the process of taking things off. Other than the aluminum engine mount arms, distributor, and the lightweight flywheel, what are the other parts i should take off to sell? mind you i need to return the engine for a core charge, so the intake manifold, block, and head need to go to the yard. Timing belt broke on this engine, and its super toast on the inside. Like exploded/cracked pistons toast.
    Whatever i pull off this engine will go for sale soon. So either help me out on what to keep, or let me know if there is something specific you want. Once i get a nice little pile ill make a FS thread.
    Oh and then engine is from an e30 '83 323i and it was a manual.
    89 325i Coupe Auto Delphin Metallic - Sold
    91 325i Sedan Auto Brilliantrot - Sold
    83 323i Euro Coupe Manual Lapisblue - Sold
    89 325i Coupe Manual Delphin - Sold
    89 325i Sedan Auto Brilliantrot
    87 325i Vert Manual Brilliantrot
  • SkiFree
    • Jun 2011
    • 2766
    Upper timing cover and valve cover are worth hanging onto. Distributor is also worth hanging onto.
    ADAMS Autosport
    • flyboyx
      • 8371
      why?
      Gigitty Gigitty!!!!
      • Farbin Kaiber
        Lil' Puppet
        • 29502
        Because someone that goes to megasquirt or other aftermarket control systems can replace the distributor with a CPS easily.
        • Hooffenstein HD
          • Nov 2012
          • 1388
          Originally posted by flyboyx
          why?
          No hole for cam mounted distributor in the B23 timing cover.
          Not sure why you'd want a mechanical dizzy though, unless you planned on carb swapping an M20.
          • M-technik-3
            • 18946
            Foe someone else that has a worn out distributor. They are not common in any stretch in the US.
            • LJ851
              • 7919
              why?
              323 cool stuff reasons.
              1) valve cover is sleek with no lumps or bosses cast in.
              2) flywheel is single mass and light (12-14lbs)
              3) upper timing belt cover is smooth and solid with no motronic dist cap mount/hole.
              4) conventional distributor is uncommon and desirable if you need one.
              5) euro
              Lorin
              The M30 is God's engine.
              • lukeADE335i
                • Apr 2013
                • 1389
                Easy & cheap LPG conversion :p
                My e30: OEM+ with M30B35
                • markt51
                  • Apr 2012
                  • 329
                  thanks for the replies so far. I started taking the engine apart last night. Turns out the timing belt didn't break, just a piston exploded lol. I know this because one of the freeze plugs is missing, and a chunk of piston was removed from the opening. So head looks great inside. The 731 head will be up for grabs as well pending the rest of it looks good once removed from the block.
                  • Sirotto
                    • 317
                    Keep what good pistons you have. A small bump in compression for the 323
                    "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." - Winston Churchill
                    "People sleep peacefully in their beds at night only because rough men stand ready to do violence on their behalf" -George Orwell
                    • HennaE30
                      • Apr 2014
                      • 1965
                      Not meaning to thread jack but what are the differences between the 731 and the 885 head? I know the 731 came on the 320 and 323, and the 885 came on the 325i, but what is the physical difference (bigger ports, etc) and also is there any power gain from a 731 over an 885 head?
                      how about if i yank the anal beads out of your ass like i'm trying to pull start a chain saw?
                      Originally posted by Northern
                      beer is my new liver cleanse.
                      Henna - '84 Hennarot 325e
                      Lola - '89 Schwarz 325is - being saved
                      Christine - '88 Schwarz 325is - Spec E30 Racecar
                      '01 White F150 Lariat 4x4 Supercrew - Daily
                      Dad's '05 Interlagosblau M3
                      • Hooffenstein HD
                        • Nov 2012
                        • 1388
                        Different ports, valves, cam and combustion chambers. #885 should also have dual valve springs but so did the late model (motronic/facelift) 320i #731. Early model 320i and 323i only have single vale springs.
                        • HennaE30
                          • Apr 2014
                          • 1965
                          So I'm assuming the 885 makes more power than the 731 because of the bigger ports and stuff?
                          • meengreene30
                            • Mar 2012
                            • 369
                            I'm running a port matched 731 head with a 272 cam, HD rockers, markD etc. etc. I can tell you it's a good time.
                            • HennaE30
                              • Apr 2014
                              • 1965
                              I was thinking of running a decked 885 head with 288 cams, HD rockers, a chip and tune on my eta, to make a 2.7i motor
