Need Advice!!!!
    Need Advice!!!!
    Timing belt snapped and I'm putting in new m20b25. Before I put the new engine in I wanted to change all the important gaskets on the engine but I don't know which ones to change. Any other ideas while my engine is out? Motor mounts, transmission mounts etc? Or should i put an m50 engine in?Thanks for all the help. This will be my first time ever swapping an engine.
    What are your plans for the car? Do u track it? Is it a daily driver? And if you get another engine, still change all the gaskets and the rod bearings.
    Originally posted by flyboyx
    how about if i yank the anal beads out of your ass like i'm trying to pull start a chain saw?
    Originally posted by Northern
    beer is my new liver cleanse.
    Henna - '84 Hennarot 325e
    Lola - '89 Schwarz 325is - being saved
    Christine - '88 Schwarz 325is - Spec E30 Racecar
    '01 White F150 Lariat 4x4 Supercrew - Daily
    Dad's '05 Interlagosblau M3
      It's my daily. I don't track it. What are rod bearings? What are all the gaskets I should change?
        Need Advice!!!!
        Then I would put an M30B35, from the 535i and the 635csi. It's the perfect daily motor because of all the torque it has (almost twice an M20). Finding one at a junkyard is like $250, all in all it'll cost about 1k to swap it, and you'll love it.
        The gaskets you should change are (and a maybe forgetting one or two) head gasket, oil pan gasket, valve cover gasket, intake/exhaust manifold gaskets, and get a new water pump and gasket (unless you just replaced yours).
        Guys add to it if I forgot anything.
          gonna need to get your hands on a bently manual!
          Gigitty Gigitty!!!!
            Originally posted by flyboyx View Post
            gonna need to get your hands on a Bentley manual!
            Definitely do. It's a life saver.
              Do you already have a new M20, or are you still trying to decide/find another engine?
              As far as gasket kits go, they come in two main sets. See here:
              Rather then swap an entire different engine, why not just replace your head? There is a good chance no damage was done to the bottom end of the engine. Get a used head, have it gone through by a machine shop (pressure checked, deck, maybe a valve grind, new valve guide seals, etc) and slap it on.
                I would agree more with Andrews advice. A swap is generally not a first timers project and a used motor may crap out on you sooner than you think.
                Seriously consider doing a head swap, might save you a ton of hassle.
                Closing SOON!
                Thanks for 10 years of fun!
                  Well the engine in my car has 400k miles on it and burns a lot of oil. My uncle gave me an engine and it has 150,000 miles o. It. His motor runs perfect.
                    dont worry about the head gasket
                    intake exhaust oilpan valve water pump timing belt cap rotor plugs motor mounts o2 sensor
