Tips on removing 260\6 trans from e32 m30
  • Mr. Burns
    • Aug 2011
    • 3516
    @ local pNp.
    can only use hand tools.
    engine & trans still mated together in vehicle.
    I've removed the exhaust, crossmember, disconnected from driveshaft and have gotten a few torn bolts out (one is stripped, will deal with that one later)
    otherwise on separating...any pointers?
    Originally posted by flyboyx
    i have watched my dog lick himself off a few times
  • ThatOneEuroE30
    • Dec 2013
    • 8626
    Pull the motor. It doesnt take long to pull the motor just unhook it if no fucks are given you can cut alot of shit to
    1991 318i 4dr slick top
    Mtech 2 turbo restoration
    • kronus
      • Apr 2008
      • 13031
      get one of those engine hoists they have, pull the nose of the motor up until it's wedged against the firewall and the trans has reasonable room around it
      unbolt
      pull
      cars beep boop
      • Mr. Burns
        • Aug 2011
        • 3516
        done deal thanks guys!
        • F34R
          sLaughter
          • 12376
          Guess that means you're going M30?!?!?!?
          Instagram: @BWeissLeather
          Current cars:
          ~ '87 325 M30B35 swap
          ~ '87 535
          ~ 01 540 Msport 6spd
          ~ '06 X5 4.8is
          • Mr. Burns
            • Aug 2011
            • 3516
            I was either gonna pull the trigger on boost or m30 today. I was tired of flip flopping.
            Got some mounts ordered today. So that seals the deal.
            • ThatOneEuroE30
              • Dec 2013
              • 8626
              So do you already have a m30 and just needed a tranny?
              • Mr. Burns
                • Aug 2011
                • 3516
                No m30 yet.
                But 260/6's are a tough find
                Edit. The tranny is attached to an m30b30 no bueno.
                Otherwise I'd take the whole lot
