Where to buy carbon fiber sheet material.
  • europeanplates
    • Jun 2005
    • 1607
    Hello,
    Anyone know of any good sources looking for a couple peices 24 x 12 x 3/16" thick. Any lead or ideas would be great.
    Tyler
    http://www.europeanplates.com Build and Preview plates
    R3V Discount Code = R3V2012
  • 2002maniac
    • 4260
    aircraftspruce will have it but may not be the cheapest.
    • Mtriple
      • 3139
      Originally posted by Simon S
      • deansbimmer
        • 674
        Some of my favorites:
        Fibre Glast Developments has specialized in the distribution of fiberglass and composite materials for over 50 years. In this time, we've built the largest and most comprehensive composites catalog in the industry; investing along the way in the product knowledge to support it. That means you can depend on Fibre Glast as a trusted and reliable resource for all your project needs. What's more, professionals look to Fibre Glast to deliver composite materials that are always First Quality. With an ISO Certified Management System in place, we work to ensure that our products meet the highest quality specifications, and that they are supplied to you promptly and with consistent characteristics each time you order. There is no exception. At Fibre Glast, we want your project to be a success, whether you're a beginner or an expert. And we're equipped to get you moving in the right direction. Let us know how we can help you.
        CST has been providing high quality, lightweight composite materials for model builders, educational projects, research and development since 1988. We stock a wide range of structural materials in carbon fiber, aramid (Kevlar) and fiberglass, including woven and unidirectional fabrics, braids and mats (veils), solid and hollow rods, wrapped tubes, rectangular shapes, carbon fiber and fiberglass plates and sheets and sandwich panels, epoxy systems, vacuum bagging and wet lay up molding supplies.
        This premium domain is part of Stack.Directory's portfolio and may be available for acquisition. Contact us if it's the right fit for your project.
        Carbon copy model aircraft parts, carbon composite undercarriages landing gear undercart cowlings cowls fibreglass fiberglass nose cone canopy cockpit spats wheel tailplate skid plate shower tray
        Aircraft Spruce is the trusted source for aircraft parts, pilot supplies, and aviation equipment. Serving certified, experimental, and homebuilt aircraft worldwide.
        McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
        advancedcompositeseng.com is your first and best source for all of the information you’re looking for. From general topics to more of what you would expect to find here, advancedcompositeseng.com has it all. We hope you find what you are searching for!
        There's a shortage of carbon fiber for many different weaves. Plate supply is also low. I havent been able to get any in a couple of months.
        Good Luck
        • nkell09
          • Jan 2004
          • 575
          also a good forum on that site called "fibre talk"
          • europeanplates
            • Jun 2005
            • 1607
            Thanks guys, some great links. I should be able to find some.
            Tyler
