Keep your old front wheel bearing/hub it helps FCAB install
  • noid
    • 1535
    If your doing or done a front wheel bearing job on an E30, keep the hub assembly, you can use it to center your control arm bushings in their carriers.
    Without the inner race (which usually separates anyways when removing a front wheel bearing), the hub assemblies inner diameter is just slightly bigger then the bushing and the lip of the hub assembly is the perfect size for supporting the control arm bushing carrier.
    Proof:
    The black plate is not required, but prevents the vise from marking up the bushing.... yes it is a backing plate from a stock radio.
    Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
    Your resource to tools and tips: www.rtstools.com
  • ThatOneEuroE30
    • Dec 2013
    • 8626
    LOLOL i leaned the same thing they help with pressing alot of things in a cause a 20 ton press cant squish it
    1991 318i 4dr slick top
    Mtech 2 turbo restoration
