After months of letting my 89 325is throwout bearing grind away, I'm ready to finally fix up her transmission woes.
After reading a few threads, I've come up with this list of parts from AutohausAZ. I want to take care of everything possible in one go so I don't have to worry about anything until I finish college. I will be buying the parts, but not doing the work as my apartment complex won't let us work on cars, and this repair makes me feel uneasy as I won't have any help either. My total comes out to ~$450 which seems reasonable. I'm posting this thread because I'd like to know what else should be replaced while the car is in the shop for transmission work. I bought the delrin carrier bushings since it's easier while the transmission is out. I've heard I should add a master cylinder to this list perhaps? Any other ideas?
Thanks!
Garagistic carrier shift bushings front+rear+clip--$22.50x1
MTC Clutch Fork Pivot; Release Bearing Fork Pivot Pin; Plastic--$0.92x1
FTE Clutch Hydraulic Hose; Master Cylinder to Slave Cylinder--$30.25x1
Fichtel-Sachs Clutch Kit--$215.60x1
FAG/Nachi Clutch Pilot Bearing; Sealed Type; 12x32x10mm--$6.71x1
Genuine BMW Clutch Pressure Plate Bolt; Plate to Flywheel; M8x16mm--$0.70x6
FTE Clutch Slave Cylinder--$31.80x1
Genuine BMW Clutch Spring; Clip Type--$2.72x1
SKF Crankshaft Oil Seal; Rear; 90x110x12mm--$17.71x1
VictorReinz Exhaust Manifold Gasket; Cylinder Head to Exhaust Manifold with Heat Shield--$10.65x1
O.E.M.Driveshaft Flex Disc/Joint; With 6 Bolt Holes for 10mm Bolts $40.31x1
Genuine BMW Flywheel Bolt; 12x28mm--$2.87x8
ElringKlinger Manual Trans Input Shaft Seal; 35x52x7mm--$4.97x1
SKF Manual Trans Shift Lever Bushing; Shift Tower Bushing for Shift Lever Pivot--$4.75x1
ElringKlinger Manual Trans Shift Shaft Seal; Selector Rod Seal; 15x21x5mm-- $2.99x1
Meistersatz/CRP Manual Trans Transmission Mount--$6.39x2
Thanks!
