E21 5 spd and bits whats it worth
  • darksideracer69
    • Jun 2011
    • 46
    I was collecting this stuff for my roundie build but i will be doing the m20 conversion. Before i pulled it i checked to make sure the gear shifting was good. All worked as it should. I believe its a 245 overdrive unit.
    Flywheel and clutch, little rusty but should clean up easily.
    5speed, has gear selector with mount, and trans to body mount.
    drive shaft
  • SkiFree
    • Jun 2011
    • 2766
    FYI,
    Before you get rid of the M10 245,
    If you're planning on doing the M20 swap then find the front section from an M20 245 and have a getrag-familiar trans shop switch the sections (not a bad time to pop in a couple syncros). This'll give you the most ideal trans for the M20/2002 swap without needing to hunt down a complete e21 323i M20 245 trans.
    ADAMS Autosport
