high shift effort
  • dreeves
    • Feb 2006
    • 99
    high shift effort
    Hi all.
    In the last month or so, the shift effort on my e30 325is has gotten pretty high... it just takes more effort to move the shift lever between gears. Before I start taking things apart, has anyone experienced this? Where should I look?
    Thanks,
    dave
    88 325is, 149k
    88 M3, JS#110
    1988 M3
    1984 911 3.2
    Ex: 1984 520i, 1988 325is, 1988 M3
    http://cars.g93.net
  • yozsi
    • Feb 2006
    • 337
    make sure your clutch slave or master cyl isnt going south. maybe your not getting enough travel on the throwout bearing fork.
    Unlimited Slip Diff's FTW!
    1972 240z Drift,Scca BSP, Scca ITS Car.
    • blueapplesoda
      • Dec 2005
      • 1904
      try Changing your tranny fluid. my first e30 barely had any tranny fluid when i bought it, and it was pretty difficult to shift. I discovered this when i had drained the tranny oil, and nothing but a small amount of black shit came out. Using redline synthetic did wonders, the way shifting is supposed to feel. Oh, and are you using the stock shift lever or a short shifter?
      • peterz
        • Sep 2005
        • 74
        My car was doing a similar thing.. snapped shifter linkage. It gradually got worse and worse, to the point where I could only use two gears, 2nd and 4th..
        • TresE30
          • Jun 2006
          • 14
          Agreed same thing with mine...new fluid and good as new! well almost besides my shiftlinkages that need new shims or whatnot.
