AC Squeaking.
  • Rouvld
    • Sep 2014
    • 569
    AC Squeaking.
    Sometimes when I run my ac I'll get this squeaking sound coming into the cabin. It doesn't happen often, but when it does it's really annoying and it only happen when my ac is on. Like if I turn my ac on and it starts squeaking and then I turn the ac off the squeaking stops immediately. Also if I'm driving and its squeaking and I make a turn the sound will get worse. Any of you guys experience this or know what it may be?
  • steve68
    • Jan 2013
    • 457
    is the blower fan locking up, take it apart and check the bearings, if it does lock up, the fuse will blow and no more A/C,
    88 M3 Lachsliber glass top, 90 IS project,
    • allen_t
      • Feb 2014
      • 552
      Blower motor might need to be cleaned out? Mine does the same and am in the process of taking it out and cleaning. Its pretty easy to access it, there are instructions online and a video on youtube.
      http://www.DeluxeCarStorage.com
      87 325ic - Early ACS Tribute
      90 325i MT2 - R.I.P
      Seller Feedback: http://www.r3vlimited.com/board/showthread.php?t=380908
      • RCtheRed
        • Aug 2015
        • 137
        Blower motor bearing, just remove the cover at the firewall side of the engine bay and it should be accessed from there, it's the hamster wheel looking contraption that is old and worn down.
        The fun never ends :-?
        89 318iS
        R.I.P 89 325i coupe
        89 335iC
