Coil, fuel pump relay, and main relay all took a shit and i'm waiting on parts in the mail. Then while i was at work today my billy sports finally came. Got home and said cool mine as well do suspension work while she's down. Followed all the step by step bullshit everyone said to do. Then lower ball joint didn't want to separate. Hit with a hammer hard as fukk....nothing and I don't own a pickle fork to which my friend said just go get one. "Yeah sure while my cars dead and not running retard" So i broke out my spring compressor and it's dumbest fucking invention ever and the rods poke into the inside of upper wheel well. I tried compressing it for a good solid hour to no avail. It started to get dark so I gave up. Can life ever go fucking smoothly??!?!?!!?!?
Pissed beyond words
Its the adventures such as that you remember on later in your life and go "the fuck was i thinking?!" LOL.
We as humans need struggle in our lives to realize the "good" parts are good.
Th sense of accomplishment when you DO finish will be greater.Comment
That cracked me up
Damn must be a bunch of comedians out in van city
And no it never goes smoothly....once I had to take an uber ride to drop off my transmission at the shop and I have spent countless hours on public transportation just shuttling back and forth from the auto store to get parts and home depot to get tools
It's good for you, builds character
Just so you know pickle forks suck and are going to destroy the rubber boots around your ball joints....if you can find it, try and get something like this
https://www.fcpeuro.com/products/bal...HhGBoCDqrw_wcB
It may cost twice as much as a pickle fork but it won't rip apart the rubber boots protecting your ball joints and will save you money in the long runComment
dude you will hate spring compressors by the end of it. Just accept the fact that they suck and will piss you off and your hands will be sore for days. The fronts are easy though. All you gotta do is get off the tie rods and control arms and you're set. Look up the bavauto video and use one of the ball joint separators. Preferably not the pickle fork. What worked for me was hitting the knuckle with a hammer once I had pressure on it. Jacking the strut up to get pressure on it will help.
once that's done you can take it off the car and deal with it there. I ended up taking the whole strut complete with rotor off and then bolting it up to a wheel which I laid on the ground and then sat on the wheel to get the shock unbolted... shit was hilarious, as in that weird kind of hilarious when you've been up for 78 hours and everything is hilarious.
it's a Kenny Powers quote on wheelsComment
Oh man, the front was a bitch when I was installing my coils. The passenger side came off easy, but I spent a while beating the shit out of my control arm with a hammer to get it off the driver's side. It eventually came off and I was sooooo relieved. The back is easy. You don't even need a spring compressor. You just need a friend. Have your friend stand on the hub of the car while the car is jacked up and on stands, then have him give it a little bounce. While he's doing that, pull the spring out. That's how I got mine out.Comment
Be VERY careful how you hold the gun when you do this. Don't grip it tightly like normal. Hold your hand to the side and grip it only tightly enough to pull the trigger. When the nut comes off, it'll kick back hard and you don't want to hurt your wrist.
I do it this way every time and it's no big deal, but you have to pay attention.2006 GMC Sierra 2500HD 4WD LBZ/Allison
2002 BMW M3 Alpinweiß/Black
1999 323i GTS2 Alpinweiß
1995 M3 Dakargelb/Black - S50B32/S6S420G/3.91
1990 325is Brilliantrot/Tan
1989 M3 Alpinweiß/Black
sigpicComment
Harbor freight sells the same thing for like $15. Works like a charm.91 318is M50 swapped
05 Honda Pilot
24V swap thread
http://www.r3vlimited.com/board/showthread.php?t=302524Comment
I just used a bfh. Broke loose like the third or fourth swing.Comment
Yup, it's what you want. BUT it's not for separating the joint....it's for putting pressure on it, then whacking the arm with a hammer. If you try to crank on those until it pops the joint loose, you're going to have a bad time.1974.5 Jensen Healey : 2003 330i/5Comment
