Help with part #
  • Rouvld
    • Sep 2014
    • 569
    Help with part #
    Does anyone know the part number for this grommet? Its on the drivers side under the steering column. Any help would be appreciated.
  • jhaurimn
    • Nov 2012
    • 2224
    What car is it on? That would help.
    Current:
    1989 325i
    1988 M3
    1987 325ic
    Past:
    2001 330ci
    2001 M3
    • Rouvld
      • Sep 2014
      • 569
      E30 325i coupe auto.
      • Rouvld
        • Sep 2014
        • 569
        Anyone?
        • Aleman
          • Mar 2012
          • 1600
          You'll have to scour realoem.com to find that one...
          R135 /// 1990 Alpinweiß II 325is
          └┼┼┘ /// 1993 Black/Black Convertible (sold)
          ..24
          • jhaurimn
            • Nov 2012
            • 2224
            I can not seem to find it in any realoem diagram. I have a feeling the grommet is part of the harness and youd have to buy the harness to get the grommet. You should put a wtb ad, Im sure someone parting e30s can cut one off for you.
            Current:
            1989 325i
            1988 M3
            1987 325ic
            Past:
            2001 330ci
            2001 M3
            • Rouvld
              • Sep 2014
              • 569
              I look for like an hour on realOEM and didn't come up with anything either. May try the dealer just to get the part number.
              • jhaurimn
                • Nov 2012
                • 2224
                I doubt the dealer will spend an hour trying to look up the part for you.
                Like I said in my previous post, you probably cant by the grommet separately. It likely comes with the wiring harness. So you will have to find a used one off a parts car.
                Current:
                1989 325i
                1988 M3
                1987 325ic
                Past:
                2001 330ci
                2001 M3
                • jdt10768
                  • Feb 2013
                  • 484
                  could check pull-a-part / what's your location?
                  I know we will be under water this weekend in Columbia
                  • Rouvld
                    • Sep 2014
                    • 569
                    Really would like to get a new one if possible. And we're already swimming in the low country man, literally lol
                    • AndrewBird
                      The Mad Scientist
                      • 11898
                      Even if you got a new one, I don't think you would be able to replace it without pulling the harness and then pulling all the pins out of the plugs so the wires could fit through.
                      • Jzenzano
                        • Aug 2015
                        • 13
                        ^^^^ i didn't know that till I went to a grave yard to collect the part and once I removed everything I noticed this. If you have a tear then just melt it together haha
                        • noid
                          • 1535
                          Email classic BMW germany, they respond fairly quickly and have access to the nitty gritty.
                          Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
                          Your resource to tools and tips: www.rtstools.com
