where can i buy pintle caps locally?
  • NC325iC
    • Mar 2004
    • 6565
    you can read cant you, what store would have them, i tried car quest i tried the stealer and a ford dealer so far ive got nothin. i need them soon
    where should i try
  • arsevader
    • May 2005
    • 1025
    NAPA - #2-12085
    Pintle Cap & Injector Seal repair kit. Dirt cheap and comes with enough caps and o-rings for 6 injectors.
    • NC325iC
      • Mar 2004
      • 6565
      beautiful, does it have the little plastic washers or should i go dig them out of the trash?
      • arsevader
        • May 2005
        • 1025
        Has everything. A pintle cap, spacer and 2 orings per injector. The caps are the smooth style without the little fins, but they are still fine.
        • X2theZ3
          • Mar 2004
          • 932
          Originally posted by arsevader
          NAPA - #2-12085
          Does that come with 6 or just 1?
          I looked it up on their website; it looks like that's just for one for 3.99.
          • arsevader
            • May 2005
            • 1025
            The kit I bought was for 6 injectors and that's the part number on the box. It was only like $15 cdn
            • delatlanta1281
              Dart Master
              • Mar 2006
              • 10317
              Mine came with one, but they were 1.99
              Yours truly,
              Rich
              you kids get off my lawn.....
              • X2theZ3
                • Mar 2004
                • 932
                Yeah,
                i was just wondering. I got mine from kragan but they didn't come as a set. Had to get them separate.
                • bimmer2288
                  • Feb 2006
                  • 273
                  Am I correct in the assumption that we are referring to the O-ring kit for the 1990 Ford Mustang 5.0 GT?
                  I went to NAPA this morning and they said that the kit had one blue cap. I looked at it and it doesn't look anything like the pintle cap that's on them now.
                  • X2theZ3
                    • Mar 2004
                    • 932
                    Yeah,
                    most will look slight differently. Let me guess, the cap was longer right? If look at the injectors, you'll notice there's a space. All the longer cap does is fine in that space, but it sits and fits fine.
                    • NC325iC
                      • Mar 2004
                      • 6565
                      DAMNIT
                      alright i went out and bought 6 of these and i went to put them on, i put the spacer on then the o ring then the cap, there wayyyy too much space btw the oring and the cap now, enough space to fit another o ring in there, and when you put them into the engine they dont go in all the way, am i not pushing the caps on enough or did i get the wrong ones?
                      Im a little pissed now cause i fucked up one of my injectors...
                      • X2theZ3
                        • Mar 2004
                        • 932
                        DAMNIT
                        which caps did you use? the napa ones?
                        • NC325iC
                          • Mar 2004
                          • 6565
                          ... nevermind i figured it out, i looked at the caps and noticed there are 2 rings inside i just didnt push them on far enough.
                          • redbull 325is
                            • 7471
                            ^^selfpwnd
                            Build Threads:
