e30 roll bar project
  • IS
    • Jul 2005
    • 366
    E30 Roll Bar
    Since the bar didn’t need to be built to any sanction specs, I decided to use 1.5” OD, .095” thick ERW tubes. The norm for ERW is usually 1.5-1.75” OD .120” thickness; however, due to the additional support bars in the design and weight considerations, I chose to go with the lighter tubes.
    First the main hoop needs to be bent. A mandrel bender has a slight learning curve and a few tests need to be performed before making your final bends. When lined up on the bender, the actual bend will starts a certain distance away from the initial mark, based on the tube thickness. After a bending a test section, it was calculated that the bend starts about .5 inches after the mark. Along with the 5.5 inch bend radius, this would have an impact on the bend marks. Rough dimensions were taken, and with the help of a little geometry, the bend marks were obtained.
    Test bend was done with a .065 tube just to confirm my calculated dimensions. One must be minding of which end you start the bend. This slipped my mind as seen in the following picture.
    Another piece of .065 was used and the dimensions needed little modification. I was ready to bend a stick of .095. Test fit went well.
    At this point, the bender was no longer necessary. The remaining tubes would have to be notched and welded. Notching was done with a hand grinder and welds with a MIG welder. The cross bar is welded in, and test fitted to make sure it clears the front seats.
    The remaining two tubes in the main hoop are notched, welded, and an unnecessary test fit is performed. Looks hot, I know. If I ever do another roll bar or cage, it’ll be buffed out nicely and clear coated.
    Next, the main hoop mounting brackets had to be made. A harbor-freight-special mill was used for this task.
    The floor pan was then drilled to match the plates.
    One design consideration was the fact that I wanted the bar to be as far away from my head as possible. Therefore, the hoop would be welded at one end of the plate. To ensure that all the force didn’t have to be absorbed by only one end of the plate, a scab plate design was used so that I could have a bolt attach inside the tube. A nut is welded.
    The mounting brackets had to be welded to the main hoop next, but to ensure proper fitment, they would need to be tack welded inside the car. Certain measures have to be taken on street cars to avoid burning any parts of the interior. A moist towel and heat/fire resistant material was used.
    Once tacked, the hoop was removed out of the car and welded completely.
    At this point, the rear bars needed to be made. Again, the plates were made on the mill, the body was drilled to match, and the brackets were tacked onto the tubes inside the car, using the same method as for the main hoop. To make it possible to remove the roll bar out of the car, the rear bars would have to be bolt on. Therefore, I made a cut about 3” from the end and would use a coupler that would have an OD approximately the same as the main tubes ID. A piece of 1.375” .12” DOM was ground down to 1.305” for this purpose. Two sections, 4” in length, were used, with 2” of engagement in both directions. One end was welded onto the main bar.
    The entire assembly was then drilled on the mill for the bolt attachment.
    Everything was lined up inside the car and tacked.
    The entire assembly was removed and welded completely.
    The weldmeister. My friend helped me with some of the welding and let me use his tools/shop.
    Now, the surface rust had to be sanded off, using 220 grit sand paper, in preparation for paint.
    It was time to paint. I chose to use duplicolor graphite wheel paint and clear coat, since I had a lot left over from painting my old 944’s wheels. It also matches the metallic paint of the car quite well.
    Ready for installation. All the mounting points are pictured.
    Installed.
    Looks a lot better in person – lighting wasn’t the best for pictures.
    Overall, the project ended up costing me about $110. I hope you guys found this interesting or learned something. Not a very difficult project but much more time consuming and requires more design considerations than expected.
    87 325IS - Delphin Grey/Cardinal
  • yozsi
    • Feb 2006
    • 337
    Mad Props!!! You da man!
    Unlimited Slip Diff's FTW!
    1972 240z Drift,Scca BSP, Scca ITS Car.
    • RobertK
      Kicked cancer's ASS.
      • Jun 2005
      • 5864
      I didn't know meat heads are into E30s too!
      j/k. Nice pics. Well done.
      • ddongbap
        • Sep 2005
        • 248
        Might as well strip that back seat, eh?
        My drinking team, has a racing problem.
        Anyone have an aquarium? If you want fish, let me know.
        • IS
          • Jul 2005
          • 366
          And make my car look like a total hack job? The seat hardly weighs anything, and this is still my main daily driver.
          I actually need to find another pair of cardinal side panels and cut them to fit. Need some insulation.
          • delatlanta1281
            Dart Master
            • Mar 2006
            • 10317
            You find me some black ones and I will trade you! I live right down the street probably!
            Yours truly,
            Rich
            you kids get off my lawn.....
            • e9nine
              • 1890
              Looks good. When you get foam - please get the highest density and highest safety rated foam since you daily drive the car. Don't skimp on the foam AT ALL...
              • IS
                • Jul 2005
                • 366
                Yeah, I wanted the bar as far away from my head as possible, therefore it is angled back a few degrees at the base.
                • s52e368
                  • 539
                  very nice work !!!
                  looks like you have a very capable welder, seams look good .
                  • ToplessE30
                    • 4791
                    Very cool! Kudos for building one yourself!
                    Estoril E36 M3/4/5 | Toledo E53 X5 3.0 | LeMans E90 335D M-Sport
                    • KangamangusDriver
                      • Aug 2005
                      • 1870
                      Those are some very clean welds my friend!
                      Nice work, looks very good!!
                      Gotta love the hands on do it yourelf approach! Props!!
                      • Charlie
                        kid tested, administrator approved
                        • 6686
                        Pray to god you never get rear ended man. That bar is scary.
                        -Charlie
                        Swing wild, brake later, don't apologize.
                        '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
                        FYYFF
                        • yozsi
                          • Feb 2006
                          • 337
                          oh, get a harness too!
                          • rs4pro3
                            • 5808
                            Dosn't look to bad, but it appears the harness bar is too high(or at least from that angle).
                            85 325e 2.7 ITB'd stroker
                            • Charlie
                              • 6686
                              Uh, yea. Where that bar sits makes it *real* bad. That stock seat is going to move 5-6 inches in an impact, and that bar sits right at decapitate/breakneck level.
                              -Charlie
                              FYYFF
