what tools should i buy??
  • E46toE30
    • Jun 2006
    • 74
    Okay. I realized that now that I own an e30 i will need to buy some tools. I have about 500 dollars id like to devote to a nice set of tools I can use for basic repairs and maintenence. Any advice on what stuff I should start with?
    1991 325ix <<sold
    1997 328is<<brothers
    1999 328i<<pops
  • assoutE12
    • Oct 2005
    • 694
    what tools do you already have?
    • bades2001
      • Jan 2005
      • 209
      torque wrench
      • ColdAccord
        • 5926
        11 and 13 mil open end wrenches and sockets, and torx sockets
        that is all.
        lol
        Originally posted by blunt
        • Rigmaster
          • 3464
          A good place to start would be one of those big tool assortments from Sears (Craftsman)- something like a 200-300 piece set. You can often find them on sale, in fact, I wouldn't buy one unless it was on sale.
          This should be a good starting point, then as you work on your car, you will find that you need some other tools, and you can buy them as you go.
          Bret.
          • 92 mtechnic cabrio
            • 4907
            -3/8in drive 8mm through 21mm metric sockets
            -3/8in drive 10mm - 19mm deep sockets
            -1/4in drive 7mm - 14mm deep sockets
            -1/4in drive 10mm - 14mm sockets
            -1/2in drive 15mm - 24mm sockets & deep sockets
            -open + box end 7mm - 19mm wrenches
            -open end 32mm wrench, thin, with 1/2in drive square on the other end, if possible.
            - 1/2in torque wrench, 10ft-lbs to 150ft-lbs should be sufficient
            - 4" 3/8in extension
            - 12-24" 3/8in extension
            - 4" 1/2in extension
            - 12-24" 1/2in extension
            - Most complete torx set you can find (probably like fifteen bucks)
            - Channel locks
            - BFH + Rubber Mallet
            - Crowbar (at least two sizes)
            R.I.P 07/01/09 - 04/23/10 :(
            • DEV0 E30
              • Oct 2004
              • 8903
              17mm hex socket (for tranny and diff drain/fill plugs) Got mine at Checker amazingly. Those and torx sockets are probably the hardest to find, and yet they aren't too hard to find. Everything else is pretty much a regular tool ... I think. No man can have too many tools though.
              Floor jacks, jack stands, pressure bleeder (1 person brake bleeding yayo), I could go on I guess.
              • asubimmer
                • 6482
                breaker bar and sawzall :twisted:
                • PУCCKAЯ_e30ka
                  • Jan 2006
                  • 1226
                  /\/\/\+BFH+torch+patience these are pretty old cars anyways!
                  • Febi Guibo
                    • Sep 2005
                    • 407
                    the above is a great list, I'd add:
                    bentley manual
                    pb blaster
                    jar of anti-seize
                    red loctite
                    carb cleaner
                    bag of shop rags
                    magnetic pickup wand
                    3/8" wobble adaptor socket
                    grade 8 (min) metric nut, bolt, washer assortment
                    rubber gloves
                    • S14E30
                      • Nov 2005
                      • 285
                      shop Lights! and beer
                      Like us on Facebook
                      • Febi Guibo
                        • Sep 2005
                        • 407
                        aww... huffing the carb cleaner beats beer... :)
                        • Avus E30
                          • 3650
                          a large set of metrick everything. eventually youll need it all
                          HDE30 <3
                          • george graves
                            • 20003
                            And a metric set of flex head gear wrenches if you have money left over. They can get into some really strange places.
                            Originally posted by Matt-B
                            • X2theZ3
                              • Mar 2004
                              • 932
                              I agree with Rigmaster. A good place to start is one of those sets from sears. That should give you most of the sockets you need.
                              Here's what I'd buy:
                              Set from Sears
                              Good set of metric combinations wrenches
                              Breaker Bar
                              Universal joint set 1/4, 3/8, 1/2
                              extension set
                              screwdriver set
                              This will take care of most jobs. You can buy a torx set later when you need them. And also, obviously a jack and jackstands if you dont have them already.
