made first long drive in the 325is
  • ptownTSI
    • Jun 2005
    • 1265
    so i finally brought it back home to where i live now, it was about 90 outside the whole way back and i had to have the heater on or it would go to 3/4 on the water-temp gauge in about 5-10minutes and i'd have to turn it back on. but when the heater was on it stayed pretty much at the half way point.
    thats about 200* at the point right?
    cooling system clearly needs some work, it has been bled, the upper hose is firm when it is warm. i think the clutch fan is bad so i'll get a new one of those. OBC said 31mpg average doing 65mph. not bad.
  • BahnE30
    • 1050
    if your running hot at highway speeds, the fan isn't the culprit, check your thermostat, and maybe a coolant flush should be in order also.
    • Hatchman
      • Mar 2005
      • 1425
      word, new t-stat and half hour of your time, and you're all set
      • ptownTSI
        • Jun 2005
        • 1265
        ok i'll put a new thermostat on and try that out.
        • delatlanta1281
          Dart Master
          • Mar 2006
          • 10317
          I dunno bout that, i was creeping in three quarter at highway speeds before replacing my fan clutch. now I am below half.
          Yours truly,
          Rich
          you kids get off my lawn.....
          • asubimmer
            • 6482
            the fan is only for low speeds when air isn't moving over the rad...
            • Teaguer
              • Sep 2004
              • 6167
              Thirded on the fan .
              A proper bleeding is also probably in order .
              • AdironRider
                • Dec 2004
                • 3491
                Fan isnt the culprit. Most likely the thermostat.
                Back to my roots
                • X2theZ3
                  • Mar 2004
                  • 932
                  +99 for the tstat and also a proper bleeding.
                  • ptownTSI
                    • Jun 2005
                    • 1265
                    keep in mind it was 90* outside when i was driving it could be the fan. If the radiator hose is pressurized and hard to squeeze do i still need to bleed it? when i did it the first time i opened the bleeder valve when it was hot and closed it when water came out.
                    • ptownTSI
                      • Jun 2005
                      • 1265
                      thanks for all the responses.
                      now the question is 80/75/71 temp thermostat... fap99 has an 80* vernet w/ seal for $7.51...not bad!!
                      • AdironRider
                        • Dec 2004
                        • 3491
                        Get whatever came stock on em, I believe it was the 80 degree.
                        Back to my roots
                        • e304me
                          • Feb 2006
                          • 1374
                          dont buy a $7.51 thermostat.
                          • ptownTSI
                            • Jun 2005
                            • 1265
                            it says it retails for $20? must be a sale. is vernet a bad brand? the only other one fap99 has is $14 and it also lists for $14. i'd almost think then by your logic the $7 one is better since it has a higher retail price??
                            • yozsi
                              • Feb 2006
                              • 337
                              the vernet is a great brand, oe on volvo's.
                              Unlimited Slip Diff's FTW!
                              1972 240z Drift,Scca BSP, Scca ITS Car.
