Part ID Help - lead to brake wear sensor. Have pics and some info.
  • CurrusDei
    • Mar 2014
    • 673
    Hey guys,
    I'm overhauling the wiring harness in my M3 and am stumped on this one.
    The housing for the lines that break out of the main harness to go to the brake wear sensor have become brittle and dry rotted over time, so i want to replace them while the harness is out.
    ECS lists p/n 61121367674, which is this:
    My line looks JUST like that except it has two lines instead of three:
    The thicker rubber areas on mine are mounting points and a protective cover, which oddly are different part numbers.
    Anyways - has anyone done this repair before? IF so care to enlighten me? If i cant find the right PN I'll probably just recover the existing line with some heavy duty shrink wrap that will hopefully take exposure better than this one did.
    Thanks!
    _______________________________________________
    5 Year M3 Build, In Progress
    RMT200 Retrofit
  • itsonlygeorge
    • Feb 2014
    • 852
    Looks like the 3rd wire is for grounding. So long as the connector fits you should be ok to use the new part.
    1987 325e Lachssilber w/ MarkD chip and late bumpers, Zender EVO spoiler, s3.25 LSD
    Originally posted by nando
    I don't think there's really strong evidence that ZDDP harms cats.
    • AndrewBird
      The Mad Scientist
      • 11898
      You can see the ring terminal next to the main plug. I would just pull that wire out of the tube and use just the two.
      • CurrusDei
        • Mar 2014
        • 673
        Yeh. Thought about that approach but if the new wire is like my original one the rubber is actually extruded around the wires, meaning pulling one out will leave a gap in the housing. Might be worth a try though. That or dust off my McMaster Carr catalogue and start looking at different gauges of heat shrink tubing
        RMT200 Retrofit
