I was just under the car installing new 02 in addition to new bmp chip and have a small wiring discrepancy. The 4wire o2 has a red, yellow, black and white while the connector is green, brown, yellow, black. I had a similar question before and found that green is power, brown is heater, yellow is signal and black is ground. On the sensor though I think the corresponding colors are black is ground (obviously), yellow signal, white heater and red power? Originally I was thinking white would be power similar to a two wire or any generic circuit but after looking at more info was persuaded otherwise. Can anyone confirm whether white or red is in fact the power supply, I could just get up and test it with the volt meter but just realized it is no longer here with me. Appreciate the quick insight as usual...
O2 sensor wiring conflicts (already searched)
