Another Central Locking
  • NotoriousShadie
    • 2
    BMW 323i 1985 Model
    I have searched all of this forum... and found nothing...
    Here it goes: I put my key into the hole and locked the doors as normal, and then i double locked it(Don't know why?!!). All the doors locked, even the trunk.
    But the problem is, I can no longer open any of the doors using the key, The boot does open and unlocks using the key. But the Driver side and passenger side do not open at all... The driver side is double locked, the passenger side is only locked. I try to turn the key in the Driver side and it does not move! and the same thing on the passenger side. The Boot CAN open and does so without any problems, However Its the doors that will not open? The fuses are perfect, I checked them all yesterday and they are all fine.
    So Im Locked out, the only thing that opens is the boot.
    How can I get into my car? at least. And how can I solve this problem?
  • typhong_e30
    • Jul 2006
    • 153
    Well BMW=- Break My Window, everything else is pretty much self explanitory or buy a slim jim and call it a mod
    BTW, Eminem is that you dawggggg.
    • redbull 325is
      • 7472
      what happens when you physically try to unlock the car by using the driver's side lock?
      Last case scenario: you break into the car somehow.. (slimjim won't work. could always take out the rear glass.) you have to unplug the locking module which is in the front driver's side speaker hole. Once this is done, you have to run 12v to the appropriate wire in it to "un double lock" the car. i *think* it was a blue/white wire.
      Best of luck.
      Julien
      Build Threads:
      • NotoriousShadie
        • 2
        fixed it thanks alot, i had to play with the key for about 1 hr then it just opened, thank god
