fuel pressure port m42?
  • paulpoko21
    • Jun 2015
    • 29
    hello
    is there a fuel pressure port on the m42?
    can you tell if it is a bad fuel pump by just looking at it?
    thanks
  • flyboyx
    • 8371
    i you suspect a fuel issue, there are several components that can be bad other than the pump. the relay and fuel pressure regulator are also possibilities.
    do you have a bently manual and volt meter? the entire trouble shooting procedure is there as well as about a hundred other threads posted here on the subject if you search for them.
    Gigitty Gigitty!!!!
    • 5Toes
      • 9836
      youre gonna need to do some real diagnosis work, like the fuel pump doesnt have a screen with a readout if its good or bad or not.
      get a DMM use your head and search and go to town on it
      • paulpoko21
        • Jun 2015
        • 29
        thanks you all
        I just took off the fuel pump shook it a lil and cleaned the lines and it turned on after over a year of sitting... i guess all i have to do is get a new fuel pump
