I am confused
  • Mike325
    • Mar 2006
    • 3685
    I am confused
    Like some of you may know, I just bought an 87 325 yesterday. I am not sure that it is an I anymore, but just a 325. The problem is that the tach reads 6500 red line, but the engine is most certanly an E engine, as well as the exhaust being single out. It even says that it is an E under the hood on a sticker. Can this motor rev up to 6500 or is it a different cluster in there? This car feels exactly the same as some I models I have drove, but my E car that I have has more torque than this one, makeing me think that again, this is an I engine. On the title for it, it says 325I as well. Someone help me out.
    Thanks.
    Originally posted by Kershaw
  • golde30
    • 11464
    did they even have 87 325i? i thought there were only 87 325IS, and the rest were 325 with an m20b27 motor...
    i say check the ECU...
    IG: @Baye30
    • DEV0 E30
      • Oct 2004
      • 8904
      Is it a 4 door?
      There was an 87 325i in the US, but it was a 4 door.
      • Mike325
        • Mar 2006
        • 3685
        Originally posted by DEV0 E30
        Is it a 4 door?
        It is a 2-door. So the ecu is 027 for eta right? Also, the cluster does not work (fuel and speedo) so I am going to take it out. There should be a vin on that right?
        • Mike325
          • Mar 2006
          • 3685
          It has an 027 ecu. Now why would it have a 6500k tach???
          • yozsi
            • Feb 2006
            • 337
            because the old one was broke and the previous owner replaced it?
            Unlimited Slip Diff's FTW!
            1972 240z Drift,Scca BSP, Scca ITS Car.
            • Mike325
              • Mar 2006
              • 3685
              That is what I think. I need to pull this tach so I will see if there is a vin on it to match it to the car.
              • 87Blue325iC
                • Apr 2006
                • 1111
                Vin??
                Aaron
                • Sean
                  • 5793
                  Originally posted by 87Blue325iC
                  Vin??
                  Vehicle Identification Number...
                  - Sean Hayes
                  • 87Blue325iC
                    • Apr 2006
                    • 1111
                    Yeah - thanks :p
                    ....I meant what is the VIN on the car, I'll pull the build sheet and solve the whole E or I question.
                    Aaron
                    • imsotyerred
                      • Oct 2005
                      • 2529
                      supereta? i bet that or replaced cluster
                      BRUTE
                      • EtaSport
                        • 2853
                        Heres an easy way. take the valve cover off. look for 7 bearing cam and dual valve springs. Easier way, look to see where the oil filter screws in. etas go right into the block, i's go into the cooler.
                        87i was a 4 door. 87is was two door. I looked at your pictures and swore it was an e, and if it has an 027 ecu it has to be.
                        Old and improved:
                        • Mike325
                          • Mar 2006
                          • 3685
                          I agree. It is an E. Thanks for the help.
                          • Sean
                            • 5793
                            Yeah - thanks :p
                            LOL, my bad dude.
                            - Sean Hayes
                            • EtaSport
                              • 2853
                              still a good deal for the price.
                              Old and improved:
