Anyone know where to get a top installed for cheap?
    Hey guys I'm new to this forum and I just was wondering if any of you knew where to get a convertible top installed relatively cheaply in Southern California. I can provide the new top but I have no idea how to install it. Thanks for the help!
    Yer welcome.
    Gigitty Gigitty!!!!
      It is not that difficult to do. It took me two Saturdays to replace the top. I used the guideline above and the original BMW videos. Google is your friend. A friendly tip...get yourself a good Dremel and a metal cutting wheel. Many of the Phillip screws are rusted and cannot be taken out. Use the Dremel and cut a line into the screw head then take them out with a flat head screw driver. You also need a rivet gun.
        Try Burbank Upholstery in Burbank it's on Burbank Blvd. I payed $420 for the install.
        Sent from my SM-N920V using Tapatalk
          With or without supplying the top? $420 for the labor is not bad.
            Correct $420 was labor, I bought the top (sonnenland material) and tensioners at German Auto Tops ($680) which is down the block from Burbank Upholstery.
