Fan clutch differences? <--- New Member
  • DeafM5
    • Nov 2016
    • 6
    Hello Everyone,
    I recently joined E30 club after few years of wanting one. I hope it meets my expectations once it is all repaired and ready for daily driving status.
    I recently picked up another fan clutch with 9 blades (Its from E30 325i). I confirmed that clutch are the same between M10 and M20 except for fan blades. Would that 9 blade fan over cool my M10 motor once the clutch locks up or should I use my original 8 blade fan that came off my M10? I think previous owner hacked up 8 blade (possibly got damaged one time and needed other blades to match to balance out rotations?).
  • MrBurgundy
    R3V Degenerate
    • Mar 2012
    • 5586
    9 blades will freeze the coolant in the radiator and blow up your engine
    • DeafM5
      • Nov 2016
      • 6
      Not sure if it is a sarcastic post. I probably end up swapping the fan clutch out and use proper fan blades.
      • MrBurgundy
        R3V Degenerate
        • Mar 2012
        • 5586
        I'm just messing with you, man. I'm not 100% but I think you're fine to use either one. Hopeful someone will chime in.
        • DeafM5
          • Nov 2016
          • 6
          Ah alright. I think I should be ok using 9 blades. Previous owner put in 71* thermostat so I will be replacing that thermostat with new 80* thermostat once I get every cooling system components squared away.
          • roguetoaster
            Biggus Tippus
            • 7830
            If it fits I suspect that you will be fine with the different fan.
            I do hope it meets your expectations for a daily, and it's always good to see someone new to E30s actually doing it properly by fixing what needs fixing before thinking power adders.
            • yngtmr
              • Mar 2016
              • 88
              You should be alright, whatever you do, don't run the messed up fan, i made that mistake when my original orange 9 blade jettisoned a blade. ruined my water pump real quick
              84 325e, Saphirblau Metallic/Houndstooth Sport, OBD-2 M52B28/ zf320
              • DeafM5
                • Nov 2016
                • 6
                I got other bmws to enjoy with power. I do love my E39 M5 with muffler delete.
                I also like to retain factory look or OEM+ looks when I can.
                Noted.
                • DeafM5
                  • Nov 2016
                  • 6
                  Looks like my new to me fan blades are too big. Stock blades are 400mm and 325i blades are 420mm. My shroud isnt big enough to clear unless I can hack my fan blade properly? I am going to try to find blades today or swap the fan clutch.
