So here's an unusual mechanical failure...
  • ELVA164
    • 4861
    Holy crap, did the center of the bracket tear out?!
    • RobTapps88
      • Feb 2017
      • 137
      I have no clue, I just picked the car up on the 18th of Jan lol I noticed it while I was doing a ghetto exhaust fix and pulling the headers... (no money is going in to that tired single cam..)
      I have found aftermarket sway brackets with a reinforcing backplate if you would like the link..
      Sent from my LG-H831 using Tapatalk
      • RobTapps88
        • Feb 2017
        • 137
        (How to edit on taptalk??)
        • lukeADE335i
          • Apr 2013
          • 1389
          Those look pretty nasty.
          Mine has just developed a weird front end clunk too, I'd assumed it was just a ball joint, but going out to check my sway bar mounts now!
          I did recently replace my front sway bar links with Meyle HD ones, so maybe mine have also let go?!
          My e30: OEM+ with M30B35
          • RobTapps88
            • Feb 2017
            • 137
            Its a possibility and easy to check ;) hope ya get yours figured out
            • pandaboo911
              • 2070
              I think this is a common thing for all BMWs, somehow they love to design subframe components such that they crack and tear.
              • ELVA164
                • 4861
                Got the car back last night and surprisingly, it drives much better with unblown strut inserts and an attached sway bar!
                • RobTapps88
                  • Feb 2017
                  • 137
                  Good to hear :) might bend mine and use a large washer to hold it on for the time being until i can get it fixed
                  • lukeADE335i
                    • Apr 2013
                    • 1389
                    Fortunately my sway bar mounts were fine. Weirdly, I put the car up on axle stands to check it, all looked fine, so I put it back down. Clunk was gone...
                    When I did the sway bar links, I did it with the car on ramps, so maybe the link had bound slightly, when I put the car on stands the suspension went to full drop it loosened up? Anyway - all's well that ends well.
                    Good to hear yours worked out!
                    • Matt-B
                      The Waffler
                      • 3856
                      Maybe you accidentally the whole thing?
                      • ELVA164
                        • 4861
                        I think I accidentally at least half and then the rest sometimes sure did.
