How do I clean this crap off of my new ellips?
  • kencopperwheat
    King of Kegstands
    • 14396
    I can't turn the aiming screws on the back of my ellips. How do I clean this off? Any ideas? I was thinking steel wool and wd40.
    Originally posted by Gruelius
  • diegom6
    • 4447
    some WD40 and anice Toothbrush and it's done.... :)
    Euro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
    • rayz
      • 494
      a thin wire brush would be better.
      FOKAI DA'MA'SHI'I ENSANE GRAPPING INT.
      • Brew
        • 3060
        PB Blaster works well for that kinda stuff.
        '91 318is
        • kencopperwheat
          King of Kegstands
          • 14396
          ? wtf is PB Blaster?
          • Brew
            • 3060
            http://www.pbblaster.com/
            '91 318is
            • kencopperwheat
              King of Kegstands
              • 14396
              I'll probably pick some up tomorrow.
              • kencopperwheat
                King of Kegstands
                • 14396
                I looked for it at 3 different places and no dice. But I was able to find some Naval Jelly Rust Dissolver that looks like it'll work pretty well. It's soaking now, and then I'll probably take a wire brush to it.
                Am I correct in my assumption that I need to unscrew those long screws to get the lights out of the brackets?
                • Brew
                  • 3060
                  Thats weird that you can't find it. Maybe its an East Coast thing.
                  '91 318is
                  • M-technik-3
                    • 18946
                    They cost $7.80 each to replace. To remove them you don't unscrew them all the way as that is just the adjuster length. You unsnap them from the plastic grommet that is mounted on the headlight unit.
                    Very simple job, remove the rings and look at them. Usually it's easier to spin the shaft lock to the frame then to unsnap the ball out while they are together.
                    • kencopperwheat
                      King of Kegstands
                      • 14396
                      I see the plastic grommet. I think it'd be kind of easy on the low beams, but the highs would be pretty difficult.
                      I don't understand you last sentence. What's the shaft lock? I don't see a ball.
                      • M-technik-3
                        • 18946
                        Look at your photo, see the white plastic unit? Rotate it 90 degrees and it will just slid out. It real is very simple, just a little time consuming.
                        The ball lock is in the plastic grommet. You generally just replace them.
                        • kencopperwheat
                          King of Kegstands
                          • 14396
                          OH! The white plastic piece? I'll give that a whirl.
                          • kencopperwheat
                            King of Kegstands
                            • 14396
                            Victory is mine!
