redoing my red tails
  • JetalonE30
    • 90
    so i think im going to re-do my red tails
    cuz theyre pretty scratched up and could use a respray
    and i was wondering, what should i use to get the old
    paint off?
    i used testors model paint and testors clear coat
  • AndrewBird
    The Mad Scientist
    • 11892
    Sand, sand, sand!
    You might try acetone however. But be careful as it can eat the plastic also.
    • JetalonE30
      • 90
      yeah, i kinda figured that about sanding
      and ill use the acetone to get in between the cracks and stuff
      thanks
      • Mystikal
        Wheel Fitment Expert
        • 9602
        Acetone and a cloth doesn't do much, I've tried.
        Sanding or something otherise abrasive would do the trick.
        • E30FreaK89
          • Apr 2006
          • 437
          get a bottle of OOPS. just spray it on let it sit for a second and the paint will bubble and then start whiping!
          • JetalonE30
            • 90
            where would i find a bottle of oops?
            • Bimmerfanatik
              • May 2004
              • 5349
              What are you using to paint them this time around? I'm thinking about painting mine - they're unpainted at the moment.
              • JetalonE30
                • 90
                ill probably use the same stuff
                testors makes model paint in translucent colors
                goto walmart and in the toy aisle
                there will be a model section
                find the model paint, and there should be some sort of a
                clear red paint, and just plain clear coat in lil cans
                cant remember exactlly what the color is called
                but theres only like one clear red ive ever seen
                thats what i used
                and im happy with the way its held up
                except for when someone decided to key one of my taillights
                • blueapplesoda
                  • Dec 2005
                  • 1904
                  polyurethane clear coat comes out much, much cleaner...i just had the guy at the body shop spray the whole tailight for me....no problems yet...
                  • JetalonE30
                    • 90
                    id need a spray gun for that right?
                    my dad has one, so maybe ill see if he can help me out
                    or take em to a body shop
                    how much did that run you at the body shop?
                    • AndrewBird
                      The Mad Scientist
                      • 11892
                      You can get automotive-grade clearcoat in a spray can. That's what I used to spray Josh's red tails for him.
                      And there is more then one transparent red color. You want Transparent Candy Apple Red.
                      Here is what Josh and I did on his:
                      • JetalonE30
                        • 90
                        cool thanks man, yeah i wasnt sure exactlly the color but i know when i went to walmart, there was only one color, but i guess other places would have different selection
