Manual Swap needed parts ????
  • E30_Quebec
    • Jan 2018
    • 1
    Hi guys, i'm new there and my english isn't very good... I'm a french canadian,I have an cirrusblau 1985 325E and i am planning to do a manual swap on my M20B27 (325E motor, 6cyl) but i'd like some help to be sure I have all the parts,
    I already have :
    -Transmission Getrag 260
    -Manual Drive Shaft
    - Clutch, PP
    -Manual flywheel
    I need:
    -Manual e30 pedals with Master Cyl.
    -hose for hydraulic clutch
    - Slave cylinder
    - Clutch fork
    - Throw out bearing
    - DSSR
    - urethane bushing for shifter
    -Transmission Fluid
    - Manual transmission mounts
    Is it all I need ? I would appreciate if someone who already did the swap could help me out on this ! Thank you very much !
  • roguetoaster
    Biggus Tippus
    • 7829
    Clutch fork stop/pin & retaining spring, flywheel/PP bolts, probably a flex disc, rear shifter carrier, cabin shifter boot (& the rest of the shifter parts).
    Just have a look at realOEM or bmwfan.info and compare diagrams if language slows you down when it comes to DIYs on forums. FYI, your language skills are just fine.
