S54>2jz
Honda K24 swap interest?
91' 318is 90' 325is
Originally posted by SonnyBuy the E30s, they ain't gonna last long
E30 can make you, E30 can break you
Originally posted by cunninglinguist View PostAny way to adapt a Getrag 240 to the K24?
There might be some decent weight savings there, and the G240 can handle the power.91' 318is 90' 325is
Agreed - that said, if you wanted to run a G240 it wouldn't be hard, it'd just be a bit of research to nut out which clutch / pressure plate and throw out bearing to use. BMWs are like lego with clutches, so you'd just need to look at different models to find the right combination of pressure plate and throwout bearing that gave you the stack height you needed.
Earlier in this thread it was mentioned that the adaptor for the BMW transmissions caused slave cylinder issues, but that would likely be easily sorted with an e21 throw out bearing (5mm deeper than most other BMWs, but same design) and if that weren't enough, a slight lengthening of the slave cylinder rod if the e21 bearing still didn't quite work.
Same as we've been doing for years adapting M20 flywheels to M42s, running M50s with e30 transmissions etc.
Originally posted by agile30 View PostSomeone on Instagram currently has one bolted in his vehicle and seems like he is further along. His screen name is byzaw
He's also a Mod here and has a build thread. And posted two posts above you.
Originally posted by LJ851 View PostHe's also a Mod here and has a build thread. And posted two posts above you.
https://www.r3vlimited.com/board/sho...d.php?t=408645Originally posted by Good & TightIt takes real man to mount a big woman, all you haters are just scared boys.
Originally posted by D3’min View PostJust throwing out an idea kswap with AWD using Honda CR-V parts
So you want to put an engine sideways in a e30 to ruin the weight balance.....
And make it understeer more?
The e30 is god’s chariot because it’s RWD.
Awd is understeer; an e30 325xi handles like shit compared to a rwd e30 325iLast edited by Wanganstyle; 04-02-2019, 04:48 AM.OBD1 M54/M52TU swap as a M50b25
Originally posted by Wanganstyle View Postan e30 325xi handles like shit compared to a rwd e30 325iMy Garage
Feedback
Instagram: Stone.Hopkins
