Boost Fuel presser
  • MSgtPearce
    • Nov 2018
    • 3
    Boost Fuel presser
    Hello,
    I have seen turbo users add a FMU or a fuel presser regulator that adds pressure under boost.
    Where and how is it installed? The ones I have seen still use the stock fuel presser regulator?
    Thanks!
    86 325es
  • roguetoaster
    Biggus Tippus
    • 7830
    I assume you are asking about a rising rate fuel pressure regulator.
    Where and how you would install it would all be based on the specific application.
    • MSgtPearce
      • Nov 2018
      • 3
      Ok for turbo application.
      86 325es
      • Jaxx_
        • Dec 2009
        • 1880
        the stock regulator is manifold pressure referenced, so it will deliver a constant 43.5psi between the fuel rail pressure and manifold pressure. Some incorrectly call this a 1:1 rising rate fuel pressure regulator.
        If you have 10psi in the intake manifold, the fuel pressure will be 53.5, for example.
        • MSgtPearce
          • Nov 2018
          • 3
          Ok that makes sense! Thank you
          But I have seen some add or use a separate boost controlled regulator when using a turbo? like a 8-1 or an adjustable. Can someone explain that setup?
          Or is it when you use a external FMU say 8-1. it will increase the fuel pressure for the boost and the stock will maintain the 1-1 pressure and the injectors will have the extra fuel for boost?
          86 325es
          • LowR3V'in
            • 4209
            it is a very old school a basic way to add fuel.
            stock will add 1psi of fuel to 1psi of manifold pressure.
            the FMU will adjust to whatever ration you need
            maybe this vid will help.
