Need help with IE Camber plate install
    Am working on installing Ireland Eng. adjustable camber plates on my e30 and am not sure about assembly on stock struts. Can someone help? I've got the strut off and the new Bilstein sport and H&R Race spring on, with the existing upper spring perch (IE site mentions using it). The upper perch or cap does not touch the top of the spring as the shock is taller than the spring (I'm sure it will compress once car is on ground). Not sure from here. Thanks.
    Tom
    How did you like the instructions that came with those? :giggle:
    Try this link for assembly: http://brandnewengine.com/bmw/ie_camber_plates/
    The springs will be loose until the car is on the ground.
