will VW scirroco wheels fit?
    I may have a chance to pick up some aftermarket 15's from a co werker. theyre on a VW scirroco. the only info I have on them is the size and of course theyre 4x100. Hes not much of a car oriented guy, so my guess is he doesnt know what an offset is. So, I was wondering if anyone knows if they would fit the E30 without spacers or hub rings.
    thanks.
    ray
    FOKAI DA'MA'SHI'I ENSANE GRAPPING INT.
    The bolt pattern will work, but the offset probably wont and you might need centering rings, whatever those things are called that correct wrong center bore size.
    BEERTECH
      just found some 15's online that are meant for a E30. they are ET20. would that be the perfect size for a 15 on our car? or what other offsetts would work?
        my experience with VW wheels is that they will need spacers, fairly large ones to look right. the rims probably will not bolt on at all, they will hit the brake caliper. E30s hate large wheel spacers on the front too, tends to make em shake really bad.
          My VW wheels fit fine. Could perhaps use a small spacer but thats when I have extra money (read: never).
          15" 33ofset.
          Sold it.
            i have corrado sebrings on mine right now
            they fit perfectly... almost identical offset ( i think bottecaps are 35 and sebrings are 38)
            and the centerbore is the same (72.1 i think)
              15" 33ofset.
              Your BBS' would look SICK with spacers. Sorry to rub it in.
                15" 33ofset.
                If any ever appear on max or something for a good price I would consider it. But I dunno. Hopefully this year ill have the clear coat off the lips and have em shining like woah.
                Sold it.
