Is there a bolt on TB upgrade for a 325is?
  • psloan
    • 9815
    This is for my 2002 - which is getting an e30 318i intake manifold and possibly a 325is throttle body. I have an adaptor plate - so I wanted to know if anyone has a larger tb that shares the same bolt pattern, ect.
    Thanks
  • Jand3rson
    • 37587
    BMP Design sells a big-bore throttle body for the M20, but the concensus view is that it's not worth it, especially not for $329.
    • psloan
      • 9815
      i guess 60mm will have to do for a turbo 4 cylinder.
      • TwoJ's
        • Oct 2005
        • 4908
        are you going to be using motronic? I would see if I could get rid of the AFM before I worried about the throttle body.
        • backtrail69
          • Jul 2005
          • 4471
          Um...I dont think he is considering his Sig says squirted. The 60mm will most likely be just fine for that application. I have seen some pretty big numbers on a 2.5 liter m20 with the stock TB and intake...so I think on a M10 it should be perfect.
          :: PNW Crew ::
          '87 325 4dr, '74 2002
          • euroshark
            • Apr 2006
            • 3491
            And AFM wont really add much restriction to a turbo'd M10, it's not going to pump any more air than a turbo 3.5 M30 unless its pushing huge boost, so a standard M30 AFM that the turbo boys use should be juuuust fine.
            • psloan
              • 9815
              I don't plan on running an AFM.
              • AdamF 88iS
                • 2051
                The TB is far from being the bottle neck on that motor. You're going FI anyway, why do you care about getting the absolute maximum flow out of it? If you were NA I could understand...
                Adam Fogg- '88 M3
                Common sense- It's the new 'gifted'
                • psloan
                  • 9815
                  Actually, I've decided on running a ~60mm tb off of a 5.0 mustang. Reason being is because it has the throttle position switch that is compatible with megasquirt. so much for my nice adaptor plate.....
