Somebody help me
  • diegom6
    • 4447
    Somebody help me
    no one seems to have the asnwer? I know some of you guys know what camber plates should I go for cheap and street use.
    Thnaks
    Euro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
  • Mike325
    • Mar 2006
    • 3685
    IE makes a good set. Think they are like $130.
    www.bmw2002.com
    Originally posted by Kershaw
    • diegom6
      • 4447
      Wonder if the street model will fit in my setup and will give me enough adjust?
        Though not as inexpensive as the IE camber plates, Ground Control now offers camber plates for Spec E30 use. Although intended to be mated up to H&R race springs and Bilstein Sports they'd probably work with other street springs/shock combos. Adjustability on the GC parts looks like it should be a bit better than the IE plates. Mine will be delivered Monday so I guess I'll find out then if they are better.
        • Keith M
          • 2338
          Just make sure that you check with the manufacture to see what camber plates will work with the type of springs you are using.On our e36 I wanted to use Ground Control plates but ran into a problem: I have H&R coil overs that are 4" ID and the GC plates only work with 2 1/2" ID springs. I don't recall what type I ended up using, Turner or Ireland or maybe the Bimmerworld ones.
          Keith
