Help my car lose weight.
  • dvs909
    • Sep 2006
    • 1149
    hey guys, over this winter i wanna drop about 100-150 pounds from my 88 325is. how would you go about doing this on alimited budget? my plan was to remove the rear seats and buy some used sport seats to replace my fronts. beyond that i'm not sure where to go.... im a total noob at mechanics, so dropping the A/C unit wouldnt be feasable, are there any other places i could lose weight fairly simply? (i do have a bently manual, so i am not tottaly in the dark.)
    ________
    Hash Honey Oil
  • asubimmer
    • 6482
    take out all the tar in the trunk, back seats out, take out the rear tar under the back seat, take out your windsheild wiper fluid resv, lexan the rear windows...
    keep in mind though that removing the tar will increase noise ;)
    • Garageaholic
      Freestyle Fabricator
      • Dec 2005
      • 5204
      --BODY--
      -Ahead of Firewall-
      I. Hood
      A. Fiberglass Ireland Engineering Race Hood (-32lbs)
      II. Fenders
      A. Fiberglass or Carbon Fiber Custom (-15lbs)
      III. Valance
      A. Strategic lightening of stock (-5lbs)
      B. Custom f/g or c/f (-12lbs)
      C. Aftermarket (-7lbs)
      IV. Bumper ('84-'8
      A. Euro bumper swap (-20+lbs)
      B. For '88, plastic bumper swap (-20+lbs)
      V. Wipers
      A. Single wiper conversion (-4lbs)
      -Firewall to Trunk Bulkhead-
      I. Windows: All the windows are up relatively high, thus all weight saved from them will help lower cg, raising handling limits.
      A. Mashaw Lexan Side Windows (-7lbs)
      B. Euro Crank conversion (-5lbs)
      II. Sunroof: Again, up high, so losing weight will help handling.
      A. Custom Closure, gutted (-4lbs)
      III. Side Mirrors
      A. F/g or c/f small rectangular (-2.5lbs) (Speaking of which, did you see the c/f ones on the race-prepped e30 M3 at the SD autocross? They were friggin tiny. Maybe 2.5x5")
      -Trunk Bulkhead Back-
      I. Trunklid: Up high, affects cg.
      A. F/g Ireland Engineering Race (-12lbs)
      II. Bumper ('89-91)
      A. Strategic Lightening (-7.5lbs)
      III. Bumper ('84-'87)
      IV. Window: Up high, affects cg.
      A. Mashaw Lexan (-4lbs)
      -Underside-
      I. Undercoating
      A. Full undercoating removal, replacement with clear coat. (For those of us who live on the beautiful West coast and in the
      deserts of the Southwest. (-25lbs)
      --Engine Related--
      -Accessories-
      I. Air Conditioning System
      A. Removal of compressor and brackets (-45lbs)
      B. Removal of associated lines and wires (-5lbs)
      II. Fan
      A.Replacement with electric aftermarket (-5lbs)
      -Bolt Ons-
      I. Air Intake
      A. Pipercross/iTg foam CAI w/ heat shield (-0.5lbs)
      II. Headers
      A. Ireland Engineering Ceramic Coated Shorty (-7lbs)
      III. Exhaust
      A. Custom 2.75” headers back, no cat (-20lbs)
      IV. Flywheel
      A. TMS/someone else lightweight flywheel (-8lbs)
      --Interior--
      -Passenger Compartment-
      I. Seats
      A. Sparco Evos (-58lbs for both)
      B. Back seat removal (-26lbs)
      II. Trim
      A. Center console removal (-2lbs)
      B. Rear quarter panel trim removal (-6lbs)
      C. Door trim removal, replacement with c/f (-9lbs)
      D. Parcel shelf removal, non-gloss coating (-3lbs)
      E. Carpeting Removal (-15lbs)
      III. Ducting
      A. Leftover A/C ducting removal (-3lbs)
      IV. Sound Deadening
      A. Removal of sound deadening in cabin and trunk (-55lbs)
      B. For 318iS, removal of sound deading in cabin (-20lbs)
      V. Dashboard
      A. Glovebox removal (-4lbs)
      B. Custom dash (-10lbs)
      VI. Steering Wheel
      A. Sparco Racer 2 (-2lbs)
      VII. Headliner: Any weight saved up here will help the cg, regardless of how little it may seem.
      A. Removal (-4lbs)
      B. C/f remake (+1.5lbs)
      -Trunk-
      I. Battery
      A. Lighter, smaller (-8lbs)
      II. Trunk Stuff
      A. Removal of jack, trim, etc (-12lbs)
      B. Removal of spare and replacement with space saver spare (-15lbs)
      --Suspension and Wheels--
      -Suspension-
      I. Control Arms
      A. M3 control arms, aluminum (-8lbs together, four pounds
      apiece)
      II. Wheels
      A. OZ Superleggera 15x7” (-12lbs combined, three pounds a piece)
      Recent Rebranding!!
      E30 SM62/S62
      E30 M60 V8
      E30 M30 Big 6!
      Instagram.com/garageaholic
      Youtube.com/garageaholic
      • dvs909
        • Sep 2006
        • 1149
        thanks m3fan i guess i know where to start then!!!
        how hard is it to remove the A/C system?
        I'm guessing you had this info stored someplace?
        you both mentioned the tar as sound deadening, sounds messy, is it?
        ________
        Mflb
        • Garageaholic
          • Dec 2005
          • 5204
          Yeah, I did not make this up. I received it from another thread, so FTR, it's not my material. The AC is not difficult to remove, Try to remove it with re-installation in mind, in case you want to sell an in-tact A/C system!
          Recent Rebranding!!
          E30 SM62/S62
          E30 M60 V8
          E30 M30 Big 6!
          • dvs909
            • Sep 2006
            • 1149
            thanks for the help guys! ill try to post pics of all the blunders i make so you old guys can laugh about it. :D
            ________
            NO2 VAPORIZER
            • YAN-3
              • Jan 2004
              • 6018
              wow, M3fan4eva, thanks bro
              • Garageaholic
                • Dec 2005
                • 5204
                Yeah, it was an old post from like a year ago. Resurrecting it back from the dead!
                Recent Rebranding!!
                E30 SM62/S62
                E30 M60 V8
                E30 M30 Big 6!
                • CleanAzzE30z
                  • Jan 2004
                  • 11794
                  good idea. I never saw this one.
                  Mariano
                  • ddavidv
                    • 344
                    A/C isn't that hard to remove, provided you can get the fittings loose for the hoses and lines. I only had to cut one on the condenser on mine. Radiator has to come out to remove the condenser, IIRC, which isn't hard except for the fan being in the way. I no longer have that problem. :D
                    You can remove all the lines up to and through the firewall pretty easily but you'll have to plug the holes where the lines enter the car or you'll have a serious water leak. I duct taped the grommet and reinstalled it; no problems.
                    The OEM seats weight a TON. Replace those with something lighter.
                    • redbull 325is
                      • 7471
                      your car has huge/heavy/ugly bumpers.. get plastics on there first IMHO.
                      Build Threads:
                      • joshh
                        • Aug 2004
                        • 6195
                        Nice list.
                        My car with the M50 is totally just a shell. I'll weigh it when I'm done for weight intrest.
                        "I cannot undertake to lay my finger on that article of the Constitution which granted a right to Congress of expending, on objects of benevolence, the money of their constituents. Charity is no part of the legislative duty of the [federal] government." ~ James Madison
                        ‎"If you've got a business, you didn't build that. Somebody else made that happen" Barack Obama
                        • dvs909
                          • Sep 2006
                          • 1149
                          plastics require more money than i would like to spend.. i have about $500 i set aside to work on my car this winter. so some nice used sport seats basically, then removing shit is my plan.
                          ________
                          DC MEDICAL MARIJUANA DISPENSARIES
