My shifter has ridiculous slop
  • ptownTSI
    • Jun 2005
    • 1265
    I don't want to put a short throw in, i'd just like to make it so that the shifter doesnt have a 4" swing while it is in a gear, and so it doesnt bang on the console in reverse.
    what do i need to do.
    • 37832
    Replace the bushings...
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • Jean
      • 18228
      Shift rod joint maybe ? Do you have a sheet metal shift console or aluminum ?
      • ptownTSI
        • Jun 2005
        • 1265
        i think its aluminum. is the shift rod joint the one that UUC charges a ridiculous amount for two tiny pieces of plastic? "delrin carrier bushing" or some crap.
        • e30frosh
          • Dec 2004
          • 2170
          Bushings would be my guess, as well.
          Every day I wake up we drink a lot of coffee and watch the CNN
          Every day I wake up to a bowl of clover honey and let the locusts fly in.
          Lobsterbacks attack the town again
          Wrap all my things in aluminum
          Beams of darkness streak across the sky
          Pink rays from the ancient satellite
          Every time I look out my window same three dogs looking back at me.
          Every time I open my windows cranes fly in to terrorize me.
          • ptownTSI
            • Jun 2005
            • 1265
            so which parts would i need.
            • erik325i
              • Jan 2005
              • 3567
              #'s 2,6,11,13
              If you want, you can also replace #8, although most people don't.
              -Erik
              • mtechnik
                • 6156
                Mine's sloppy too like soggy cornflakes ..
                • ptownTSI
                  • Jun 2005
                  • 1265
                  mines sloppy like a lesbian college orgy.
                  • mtechnik
                    • 6156
                    graphic stuff!
                    • Dustin
                      • Dec 2006
                      • 73
                      i was going to say, join the club.. but, yours isn't as bad as mine.. and i think the slop plays a role in second working when it wants to. i am upgrading to a short shifter though. i just wish there were more options for me since i have the sheetmetal one, i think.. i SHOULD atleast.
                      1985 325e w/ i motor swap
                      • erik325i
                        • Jan 2005
                        • 3567
                        You should upgrade to the alluminum shift carrier.
                        -Erik
                          • 37832
                          My Eta has the sheet metal style shifter. I replaced EVERY wear item on the shifter and linkage and installed a Z4 2.5 lever and it's fuckin awesome.
                          Grover Beach, CA
                          www.BimmerHeads.com
                          • T.Dot E30
                            • Mar 2004
                            • 536
                            I replaced all the bushings on mine and i still have some slight play.
                            It felt like it was the part on the tranny that the selector rod connects to causing the play.
                            Tranny is probably fucked.
                            • Jonathan M3
                              • 1837
                              #19 in that pic plays a large part in the shifter slop as well. Its a piece of foam rubber that firms up the pivot point between #13 and the rod attached to the tranny.
                              I replaced it with a more beefy piece of rubber hose and it made a world of difference.
                              '05 E46 M3 Imolarot/Cinnamon - CURRENT
                              '98 E36 M3 Estorilblau/Dove - SOLD
                              '90 E30 M3 Brilliantrot/Black - SOLD
                              SRS BSNS Motorsports - 24hrs of LeMons Racer
