TCD 325i Turbo Dyno Results
  • TCD
    • 438
    Here they are. It's ugly but not bad for the first time out. The engine falls flat on it's face from 4500-5000rpm. It's either an ignition rpoblem or timing issue. Otherwise the car runs great. It made really big HP at 259RWHP but torque really suffered at only 238RWTQ. That number should be closer to 275-280.
    Todays temperature was a full 20F warmer than the baseline pull but the turbo added a full 112RWHP over stock at only 12psi non intercooled. I am very happy with that improvement.
    Just to recap. 1989 325i bone stock motor with 151,115 miles on the untouched engine. TCD non intercooled turbo kit running 12psi non intercooled. TCD 3" exhaust. All dyno pulls in 3rd gear. All numbers SAE.
    [img]http://groups.msn.com/_Secure/0QwDYAq4R3iaqBPY*Ryy0xamLJQAJQIqBUU*HpMateelfJXgSy 9pUhHDubUsgfbp8HN7KrXqI6xp*75ky24gwu5sjKd0JVjpbHcD lARs3GCY/IMAG0024.JPG?dc=4675465192859805535[/img]
    [img]http://groups.msn.com/_Secure/0RwDRAoUSKm!qBPY*Ryy0xS7uD7afmCMOhAjhtk6JaAg0!Zbbt eFvTux1GVpFU*gkzYFQ!!22cOQdKejDI1ujMtGsmsXsAxm3NGo BtQrvgsM/IMAG0004.JPG?dc=4675465442061650341[/img]
    [img]http://groups.msn.com/_Secure/0RwAJA4YSaG!qBPY*Ryy0xSpgXPMnZajstwM2ERW7e1wVGGqi0 EjMiGK4gthUrzpLnKsRQ0h5f*aIvuNO*JWvP*NjJUqZGdnaxHw fREHDYHE/IMAG0005.JPG?dc=4675465442064636139[/img]
    Todd
    TCD
    1985 euro 535i
    503rwhp/485rwtq
  • Erick
    Official R3V Drifter
    • 11169
    wow :shock:
    Great numbers! Props to you for those results!
    ..::Support FullOpp::..
    FullOpp Stickers for sale!
    Feedback Thread
    • Stu Mc
      • 4083
      Great numbers for sure. On a dynojet, that's well over 300 horsies. :D
      Why did you use 3rd gear? Just curious. I was told that with a 3.73 (you may not have the stock diff, i dunno), 4th gear will give you the most accurate reading.
      Killer sleeper. 8)
      • TCD
        • 438
        We are running a 3.25 diff and it's just alot easier on the car in 3rd gear.
        The base run was down in 3rd gear with a 3.73 diff.
        Thanks,
        Todd
        TCD
        1985 euro 535i
        503rwhp/485rwtq
        • E30godz
          • 1524
          wow im impressed!
          • Brew
            • 3060
            Wow, great numbers!
            I would love to see this thing in person. You should come up to one of our F1 Boston meets.
            '91 318is
            • Rob
              • 8166
              some tuning and the will be a great power curve, good job
              BEERTECH
              • bimmerlover
                • 424
                Sweeeeet! An E30 with 259RWHP has to feel quick. I wish I had a car your turbo kit would fit on. I'll have to work on that. :D
                • matt325is
                  • 409
                  Good work Todd,
                  I'm glad it all came together without problems! A lil tweaking, and I'm sure it will run VERY nice. Any date set on dyno'ing the intercooled kit?
                  Matt
                  • OreoGaborio
                    • 1285
                    Todd, you busy on Sunday? there's a GTG at the Natick Mall. should be a big showing w/ alot of different cars
                    -Pete
                    LRRS/CCS#187 ECK-Racing, Ironstone Ventures, Tony's Track Days
                    Pine Motorparts/PBE Specialists | Phoenix Graphics | Woodcraft | Moon Performance | RJ's Motorsport | Motorcycles of Manchester
                    The Garage: '03 Tuono (Hooligan bike :naughty) | '06 SV650 (race)
                    • CobraKai
                      • 1544
                      very nice numbers!
                      thats a fine lookin' sleeper. :)
                      -alex
                      i take pictures.
                      • bwanac
                        • 3354
                        http://www.dtmpower.net/forum/showth...hreadid=127179
                        Oops, I guess Pete beat me to it!
                        Definately come up, I would love to see it. And show it off to those damn e36 boyz! :D
                        • Alex Mc
                          • 281
                          What are the manifold air temperatures? 12psi without cooling the charge is probably not too wise. Good numbers, but you're gonna be dealing with really hot combustion i'm guessing, which will probably lead to melting a piston if the bottom end isn't forged (pistons).
                          Current: Brilliantrot '91 318is M20B25
                          Former: '88 M3 3.2L, '91 318is 2.0L, '90 318i, '85 325e 2.8L, '84 318i 2.0L, '84 318i, '90 325is
                          wamchenry@gmail.com
                          insta: @simple_machines
                          • OreoGaborio
                            • 1285
                            what alex said.... i saw an imprezza 2.5rs throw a rod at the dragway cuz he was running about that much boost non-intercooled. cool thing was it puched out a chunk of the block about the size of a silver dollar, and on that chunk was the engine code casting... nice little souvenir ;)
                            -Pete
                            • STS
                              • Mar 2004
                              • 7
                              The issue with heated charge air is that it can contribute to pre-ignition (spontanious ignition) and'/or detonation... two distinctly different phenomena, both of which can be destructive to an engine via either extreme temperatures, as in pre-ignition or extreme cylinder pressures as in detonation. This car, at 12 psi, had an air charge temperature of approximately 170F and suffered none of the above mentioned symptoms. The TCD 535 has run 18psi non-intercooled (charge temp 250F +) without these symptoms.
                              At this point, we are not concerned running these boost levels non-intercooled. We are testing the limits of these systems and at this point we feel we have not pushed the 325.
