Pics of my new turbo set-up if you want to look.
  • 89325iturbo
    • Mar 2004
    • 723
    Apparently i can post pics on this forum if my life depended on it. So if you want ot look i'll let you guys know my password. Click on the link to skip you over, and my user name is 89325iturbo and my password is amanda. Theres some pics of my old set-up and some of my new one along with some pics of my car the one with the SSR's, and my brothers car with the BBS RK's. Its a couple steps, but if you want to look their, there
  • 89325iturbo
    • Mar 2004
    • 723
    Or maybe you don't have to type my login crap.
    • diegom6
      • 4447
      pretty nice Stuff you got there Dusty...
      Someone can delete you pics if you are giving you user name and password.. :P
      Euro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
      • skat 325is
        • 296
        Did your wastegate cleared the engine mount ?
        • OldUser1
          • 636
          Nice looking turbo setup.
          BTW to post pics insert the url in between [img]URL[/img]
          • 89325iturbo
            • Mar 2004
            • 723
            Thanks Guys,
            On my old set-up the wastegate was never next to the motor mount, it mounted up top you can see it in a couple of the pictures. my turbo was right on top of the motor mount. On my new set-up the T/60 turbo is to big to fit down bottom because it would hit the motor mount. Thats why i just flipped the exhaust manifold over to make it a top mounted turbo
            I tried everyway to post pics nothing worked, i trust people not to erase my pics from the folder
            • 89325iturbo
              • Mar 2004
              • 723
              You might want to change your forum password as well, since it's the same as your photo host one :roll:
              • TCD
                • 438
                The ports are asymetrical. How did you just turn it upside down? The bolt holes will line up but the ports won't.
                Todd
                TCD
                1985 euro 535i
                503rwhp/485rwtq
                • 89325iturbo
                  • Mar 2004
                  • 723
                  Good catch Tood,
                  Yeah the ports are off, i dremeled the bottom sides of the exhaust manifold ports to open it up more. There not off by to much now. But you got me a little concerned about the flow now that i've been thinking about it again. Maybe i should go back to what i did originally. Flip the exhaust manifold back over to the way its suppose to go, then put the adapter peice i made on it. Which was just a U-bent pipe with the flanges connected to both ends. So it would still be able to be mounted up top to give me the clearence i need. It may not look as clean with the adapter but the flow might be better.
                  • e30Matt
                    • 5077
                    That's a pretty big turbo :eeek:
                    • 89325iturbo
                      • Mar 2004
                      • 723
                      Incase anyone is curious about my set-up, or wants to know what i have here you go. heres what i got, some parts new some old.
                      JE 8.2:1 forged pistons
                      stock rods
                      stock crank
                      Garrett T/60-1 turbo
                      Raceware head studs
                      Sperco front mount intercooler core size 18x8x3
                      30 pound injectors (probably should have gone with 36lb)
                      Walbro fuel pump -hopefully TCD can help me with that
                      Vortech 12:1 FMU (probably get rid of it in a couple months)
                      Mosselman manifold
                      Msd 6BTM igniton box
                      3 heat ranges colder spark plugs
                      8mm wires
                      blaster ss coil
                      Aquamist water injection
                      deltagate wastegate
                      turboXS BOV
                      turboXS boost controller
                      Clutchmasters stage 2 clutch
                      felpro head gasket, (O-ringing was gonna cost to much)
                      All new bottom end, top end gaskets, new motor, and transmission mounts
                      new stock cam, rocker arms, valveguides
                      new main, and rod bearings.
                      Theres probably a couple things i forgot about ect...
                      .I've tossed around the idea of a few different fuel, and engine management set-ups. But i decided im going to go with the Haltech E6X stand alone set-up. Which means i won't need my MSD6BTM ignition anymore. After the break in period for the pistons, and rings im going to get it dyno tuned up at KTR Performance in Mass. I want to run 16 psi to get around 315-325w hp. We'll see though its tougher with are SOHC engines to make big power.
                      • 89325iturbo
                        • Mar 2004
                        • 723
                        I uploaded some pics of the JE pistons installed in my block onto we-todd-did-racing if you want ot take a look.
                        • iXer
                          • 242
                          The Mosselman manifold is really poor. If I had to find one thing that really hurts your spool-up time and response, that would be it. The rest of your setup is very good, but that manifold got my attention in a bad way.
                          Check out my post in this thread: http://www.r3vlimited.com/phpBB2/viewtopic.php?t=2612
                          • 89325iturbo
                            • Mar 2004
                            • 723
                            I wish i could get an equal length tubular manifold. I was loooking at proturbo's, but for $900 by the time it got shipped here was a little to pricey. If i was building a crazy high horsepower power car i would definately go with one. A log manifold is still a good manifold, not the best but it will still get the job done. I used it with my last set-up, and it worked very well for what i was using it for, so i have no worries about using it with this set-up either.
                            • Widebody325
                              • 417
                              Hey Dusty. Good to see you here. Lookin good man. I gotta come over and check that out. Did you send your block to that machine shop in Putnam to get the pistons put in? I can make you a mandrel bent manifold adapter for the turbo if you want. Email me or something, maby we can work something out. Talk to ya soon,-Ben
                              Follow me @baysidefabrication on Instagram
