318is Clutch Options
  • 02stu
    • Jan 2005
    • 872
    I just finished swaping a m50 into my 318is and unfortintly left the stock clutch which burned up in no time. I'm having trouble finding aftermarket 318is clutches, so I was wondering if I could use a clutch made for an m20, what about an e36 318? Also does anone have an unsprung clutch in there car, how horrable are they? What would you recomend? I'm using the getrag 240 transmission.
    Thanks
    Stu
  • AdironRider
    • Dec 2004
    • 3491
    Second question if you dont mind.....
    Would the m20 clutch flywheel swap still work if one were to swap in an m50? Do you even use the dual mass flywheel from the m42 to do this swap?
    Back to my roots
    • FredK
      • 14761
      I know Spec makes M42 clutches that can hold more torque.
      • 02stu
        • Jan 2005
        • 872
        I'm using the m42 dual mass flywheel right now, are you saying you can swap a m20 flywheel and clutch into a 318? Does Spec only sell clutch kits, I just want to buy a clutch disc right now.
        Thanks
        Stu
