complete guide to men's tools
  • Rennsport
    • 2139
    1. DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against that freshly painted part you were drying.
    2. WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprint whorls and hard-earned guitar calluses in about the time it takes you to say, "****!!!"
    3. ELECTRIC HAND DRILL: Normally used for spinning pop rivets in
    their holes until you die of old age
    4. PLIERS: Used to round off hexagonal bolt heads.
    5. HACKSAW: One of a family of cutting tools built on the Ouija
    board principle: It transforms human energy into a crooked, unpredictable motion, and the more you attemp t to influence its course, the more dismal your future becomes.
    6. VISE GRIP PLIERS: Used to round off bolt heads. If nothing else
    is available, they can also be used to transfer intense welding heat
    to the palm of your hand.
    7. OXYACETYLENE TORCH: Used almost entirely for setting various flammable objects in your shop on fire. Also handy for igniting the grease inside a wheel hub you're trying to get the bearing race out of.
    8. WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16 or 1/2" socket you've been searching for, for the last 15 minutes.
    9. HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new disk brake pads, trapping the jack handle firmly under the bumper.
    10. EIGHT-FOOT LONG DOUGLAS FIR 4X4: Used to attempt to lever an automobile upward off a hydraulic jack handle.
    11. TWEEZERS: A tool for removing splinters of wood, especially
    Douglas fir.
    12. TELEPHONE: Tool for calling your neighbor to see if he has
    another hydraulic floor jack.
    13. SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for spreading mayonnaise; used mainly for removing dog feces from your boots.
    14. E-Z OUT BOLT AND STUD EXTRACTOR: A tool that snaps off in bolt holes and is ten times harder than any known drill bit.
    15. TWO-TON HYDRAULIC ENGINE HOIST: A handy tool for testing the tensile strength of bolts and fuel lines you forgot to disconnect.
    16. CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large motor mount prying tool that inexplicably has an accurately machined screwdriver tip on the end without the handle.
    17. AVIATION METAL SNIPS: See hacksaw.
    18. TROUBLE LIGHT: The homebuilder's own tanning booth. Sometim es called droplight, it is a good source of vitamin D, "the sunshine vitamin," which is not otherwise found under cars at night.
    Health benefits aside, its main purpose is to consume 40-watt light bulbs at about the same rate that 105-mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading.
    19. PHILLIPS SCREWDRIVER: Normally used to stab the lids of
    old-style paper-and-tin oil cans and squirt oil on your shirt; can
    also be used, as the name implies, to round off the interiors of
    Phillips screw heads.
    20. AIR COMPRESSOR: A machine that takes energy produced in a
    coal-burning power plant 200 miles away and transforms it into
    compressed air that travels by hose to an Pneumatic impact wrench
    that grips rusty bolts last tightened 70 years ago by someone at GM,
    and rounds them off or twists them off .
    21. PRY BAR: A tool used to crumple the metal surrounding that clip
    or bracket you needed to remove in order to replace a 50 cent part.
    22. HOSE CUTTER: A tool used to cut hoses 1/2 inch too short.
    23. HAMMER: Originally employed as a weapon of war, the hammer
    nowadays is used as a kind of divining rod to locate expensive parts
    not far from the object we are trying to hit.
    23. MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on boxes containing upholstered items, chrome-plated metal, plastic parts and the other hand not holding the knife.
    *So there you have it: a complete description of the tools all men
    need, and occasionally use correctly.
    m106 1990 e30
    e36 daily
    e32 cruiser
  • NC325iC
    • Mar 2004
    • 6565
    lol, nicely done
    • Jand3rson
      • 37587
      A repost from back in the day, but funny as shit nonetheless.
      • golde30
        • 11464
        this one made me LMAO.
        IG: @Baye30
        • turbo_negro69
          • Dec 2006
          • 468
          good stuff man! :rofl: :rofl:
          91-318i SOLD : (
          91-318IS for sale
          95-740i DD
          84-Monte carlo SS Under construction
          90-T-bird Supercoupe DD
          • Rennsport
            • 2139
            sorry for the repost, but its worth it in my opinion!!
            m106 1990 e30
            e36 daily
            e32 cruiser
            • browntown
              • Jun 2004
              • 3524
              I think I'm going to print it and pin it to the wall of the garage for those many smoke breaks (read: calm down break before I start using the 3lb sledge on delicate parts)
              Might brighten my spirit, and unclog the gears between the ears.
              • DEV0 E30
                • Oct 2004
                • 8901
                Agreed, only because I've done that, but it was coolant hoses. They hold up quite well.
                • PiercedE30
                  • Apr 2005
                  • 4220
                  that was funny
                  My 2.9L Build!
                  • Court M3
                    • Jan 2004
                    • 6713
                    good one, think I'll pass it along to some of peeps
                    Continuous For Sale Thread
                    323i s50
