Does any one know where i could find some good literature about swapping the 323i head onto an eta block? thanks Matt
325e 323i
Matt- It's basically the same as swapping a 325i head on, only you are using a different head. You'll need 325i intake, throttle body, intake boot, afm, icv, fpr, crank pully and sensor, engine wire harness, injectors, and ecu. Check strictlyeta.com or .net (I forget) for a write up on swapping the 325i head on.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image. -
somewhere here, there is a scanned article from a british magazine about the easy stroker. The brits have those heads lying in heaps on the side of the road, so they talk about it like the poormans power 2.7. I can't find it quickly, but I'm sure someone knows the link.Comment
thanks. found some more info. on the swap. here is the link.
