I've seen several cabrio's without the ugly third brake light on their trunk lid. I found out mine is leaking really bad, and I'd like to remove it. I know there will be holes left over, so what do you guys recommend be done about those? Can a body shop cover them up or something? Could I get a trunklid from another E30 without the brake light and have it painted to match? I already have most of the light off, i'm just not sure what to do with the harness. It doesn't appear to come off of the bottom portion and I really don't want to cut it. I can't imagine it doesn't unplug from somewhere but I can't seem to find where it would.
Cabrio deck lid brake light removal?
Looks like your trunk sheet metal problem is solved - thanks to Luke! The wiring for your brake light runs across the underside of the deck lid, down the hinge, behind the trunk liner. Their is a fastener plug right by the underside of the antenna to unplug the light. Now once you change deck lids & you get rid of it, your check panel "brake light" will stay on.
No one seems to have an answer on this board, as too how to jumper wire the plug or get the same resistance as (the now gone) bulb - @ 4 ohms - so the stink'n "brake light" will go out on the check panel. Any solution to this would be appreciated!!
Jack[IComment
Just bypass the little PC board and solder the wires together.
When I first bought my Cab last year, the Brake check light wouldn't go out, even though everything was working.
Bypassing that little 1" x1" or so PC board did the trick.
Jacksigpic
1988 5 spd.Cabrio/Lachs Silber/Black Leather/123k/Dealer Serviced & Maintained by both PO's
Clarion DXZ785USB HU, BBS Wheels, Leather e-brake handle & e-brake boot, Mtech 1 Wheel, Maplight Mirror, Performance chip, Rear Headrests.
Previous E30: 1986 5 spd. 325es/Delphin Gray/Black Leather/191k
I like the idea!! Which PC board are you talking about - in the trunk wiring for the 3rd brake light - or the check panel above the rear view mirror?
[IComment
there are 4 wires in there i cant remeber the color but there are 2 that are the same color that go to the check control, splice them together problem solvedYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Originally posted by TimKninjaIm more afraid of this thread turning into one of those classic R3v moments, where Pizza gets delivered.Comment
