E34 battery drain problem HELP!!
  • MIZTERIO
    • 993
    Hello guys I need your help with my 1991 525i battery drain problem. Originally I bought a new Battery (Duralast) on september 2006. The battery was doing good all that time. On February 15 my car was completely dead, no interior light not even the car alarm was working NO ENERGY at all. The battery had a warranty I took to the store adn replaced for a new one. I installed my new fresh battery on february 16, 3 days later the car was dead AGAIN! no interior lights, no signs of life , not even the car alarm was working. the first battery last me for 5 months and the second battery for 3 days. what can be the problem?? what can be draining the battery??
    thanks guys in advance!!!
    IT IS BETTER TO DIE ON YOUR FEET THAN LIVE ON YOUR KNEES - emiliano zapata!
  • 87' 325
    • Jul 2005
    • 215
    If you drive it alot it may be the alternator.
    • xLibelle
      • Aug 2004
      • 2673
      when you hook up the polls, does it spark a little?
      you need to perform a leak test AND have an auto store check your alternator
      • AdamF 88iS
        • 2051
        Check if any of the power seat switches are getting stuck.
        If thats not it, pick up a multi meter that can measure load. Hook up the meter and pull fuses one at a time until the draw disappears... then you'll know where to look.
        Adam Fogg- '88 M3
        Common sense- It's the new 'gifted'
        • MIZTERIO
          • 993
          yeah it sparks alittle.... I forgot to mention the store check the alternator.. he said something like 13.6 v.. he said it was goog. :roll:
          • MIZTERIO
            • 993
            i barely use the power seats.... I checked them anyway and they are not stuck.. am gonna buy a meter and do that test..
            any more sugestions???
            THANKS GUYS!!
            • Nick
              • Oct 2006
              • 279
              Again, a blown voltage regulator on the alternator can cause this problem.
              I had a problem like this on my old e32...it ran fine, then poof, no power.
              It ended up being a bad alternator.
              • AdamF 88iS
                • 2051
                True, but he tested 13.6v, which is pretty text book. If it was charging at 14+ then yea, bad regulator.
                Adam Fogg- '88 M3
